Case Mod - In Progress SAKSAK 800 D CASE MOD+ Watercooled with Copper and Acrylic pipe update 06 AUGUST2014
Discussion in 'Project Logs' started by arg-ist, 28 Apr 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    new case is an old friend CORSAİR 800D.
    The original case
    What I want to achieve are:
    To modify 800D case
    To instal watercooling1x loop with 2x rads (Push-pull)
    To install liquid cooling via Copper and acrylic pipe.
    To use a special distributor for water distribution as midplate, laser cutted.
    To enlarge the case for radiator fans since it is not wide enough.
    MB
    ASUS R4 Black Edition
    WB for MB
    EK-FB KIT ASUS R4BE Nickel Plexi Clean CSQ
    Cpu
    Core i7 4820K 2011 3.7GHz 10MB
    WB for CPU
    EK-Supremacy Clean CSQ Nickel Plexi
    Video card
    2X ZOTAC GTX780 AMP! GDDR5 3GB 384BIT NVIDIA GEFORCE DX11.1
    WB for Video
    2X EK-FC TİTAN SE Nikel Plexi -Clean CSQ
    RAM
    AVEXİR CORE SERİES 8X4
    Rezervuar
    EK –X2 250mm
    PSU
    CORSAİR Prof. Ser. Gold AX1200 — 80 PLUS
    Rad
    1x Alphacool NexXxoS UT60 Full Copper 360mm
    1x Alphacool NexXxoS Monsta 240
    Pump
    Swiftech MCP655™ Series 12 VDC Water Pumps - With Speed Control
    Shroud
    1x Koolance 4-Fan Radiator Shroud, Black
    Fittings
    30x Bitspower G1/4" Matte Black Enhance Dual Multi-Link For Acrylic Tube OD 12MM
    Fans
    12x CORSAIR Air Series SP120 High Performance Edition High Static Pressure 120mm Case fun
    The case naked
    Adding a backplate for the new case
    The new place for MONSTA 240 and SWİFTECH 655 pump
    Youtube added
    https://www.youtube.com/watch?v=0MtxDyE1boU
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
    Graphic Equaliser Display
    http://forums.bit-tech.net/showthread.php?t=277610
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Made an alu midplate for plexi water distrubutor.
    Midplate and backplate mat black painted
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    to enlarge the case , fans were taken out of the case
    I made a radiator shroud for fans
    and used a self made lazer cutted rad grill on the shroud
    Corsair 800 D has a 360 rad gril on the top.
    I want to use an Alphacool UT 60 – 480 RAD on the top of the case . therfore ı added 4th
    120 mm fangrill with drilling .
    but there was a problem to mount the 480 rad . on the top of the case was a pit 5mm for 360 rads
    these coused problems at the inside and outside.. ı solved these problem with a 120 mm gasket at the inside and a self made 5mm rubber 360 gasket at outside..
    Alphacool UT 60 480 mounted on the topwith push-pull fans and Koollance shroud
    480 mm rad mounted on the top
    pull fans mounted with koolance shroud
    And Monsta 240 mounted at his place.
    One of Connection threads from Monsta , was used for draining with a single rotary 90 adapter and a mini valve of Bitspower.
    becouse pull fanns of monsta was at outside of the case. , it was made an shroud onthe backcover.
  4. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    update 17/05/2014
    and planning the way for cupper pipes from MB(White line)(blue acrylic)
    and next planning of acrylic pipes (blue line)
    and bending of copper pipes.
    in and out pipes of 480 rad changed
    New 5.25 cages with 60 mm depth instead of original 180 mm depht
    Added CPU acrylic pipes
  5. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    working a bit more with pipes of southbridge and (VRM / MOSFETs) modüle . changed angels of bending…
    45 a
    the green marked pipes must be riht angle and the the pipes blue marked must be paralel
    and done…
    and the hight of the pipes.the distance between MB and pipes was 100mm and it is downloaded to 50 mm
    acrylic pipes of video cards added. ( only one videocard is at photo)
    I wannt to make a BLACK plexi(glossy) backplate. And RED plexi gromets for cables.
    and what ı wannt to do as backplate..
    And done
    and planning of plexi waterdistributor as mid plate.
    And what ı want to do. Black plexi and blood red fluid with ROG logo.
    And drawn with corel to cut with lazer.
    UPDATE 29/05/2014
    To separate PSU from watercooling ,and to hide the cablles ı made a seperatör.
    added a filport to the case.
    the topmost black plexi cutted with laser to control the dimensions .
    illuminated relief rog logo
    Added gromets for cables.
    UPDATE 5 JUNE 2014
    Becouse there is no place at 5.25 bay for SSD s and HDD, ı made special trays for them . I used 15X15mm Alu T Profil.
    And trays mounted to HDD and SSD
    And all mounted to the case.
    The plexi Water distrubutor has 4 layers.
    1- 5mm black plexi at buttom
    2- 10mm clear plexi (with lazercutted water channels) in the middle
    3- 5mm clear plex on the top i for fittings
    4- 2mm black plexi as mask
    First bonding acrylic sheets with cloroform. layers 2 and 3
    Two layers bounded with cloroform
    First leak test
    And leak test passed with success.
    Dont use metal drils
    tapping and preparing for fittings
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 12/06/2014
    Next step, bonding the buttom black plexi from the inside.
    And bonding the top plexi as mask with logo
    The black plexi mask at the top is 5mm larger from all sides to illuminate the main plexi with a strip led.
    And with led strips to control
    Acrylic tube fittings mounted to distributör.
    The 2.nd leak test with green fluid. The fluid was a brite grenn primochill
    but it seems as a dark pastel fluid becouse of black buttom plexi.
    quick illuminated to see the real color.
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    ORGANİZİNG 5.25” DRİVE BAYS 1
    The depht of my 5.25 drive bays is only 60 mm. Bu ı want to use it
    1 - I want to use the ON- OF control panel of corsair 800D.
    2- I want to use my Thermaltake media lab
    3- I want to turn of the power of the HDD if it is necessary.
    I could use my self built 4 way HDD switcher
    But ı made a new controller for leds and HDD switcher together
    I have 3 ledsrips in the case and 6 leds on blocks. I want turn of the leds strips and dimm if it is necessary . Therefore ı usued 5 K ohm ON-OF pottanciometers. And red leds to see the on- of positions.
    And one 2 way ON-OF switch for HDD with a yellow led on
  8. Randhart
    Randhart What's a Dremel?
    26 Apr 2014
    Loving the work so far, just a question are you keeping the industrial look or will you be smoothing/filling the points where the Alu meets at the bends?
  9. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    they will look smooth, if they are mat black painted...
    but ı like the industrial look more ... for example ı use right angular shapes and imbus bolts on my mods. you cann see at my mods like these
    industral works are beautiful for me.
  10. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    4 - I want t to use a fan controller , Lamptron FC5 V3, to control rad fans (13 fanns on 240rad and 480 rad - push-pul)
    And control the fluid temps at rad outputs , with aquacomputer inline sensors on Lamptron
    I will to monitor the pumps speed on lamptron and control the pumpspeed with FC5V3 (it has 30 watt outpoot per chanell)
    But my old swiftech 655 has no tacho output to monitor accurately the pumps speed. İt must be modified .
    First the tacho outpoot must be found on the PCB
    scraped the coating off the little circle at PCB with a dremel till I see copper .
    Soldered a 3 rd wire to monitor the pump speed
    Changed the power cables and used a 3 pin female fan connector , to connect it to fan controller.
    You can see the speed of pump on LCD Display and adjust the speed with knob at Lamptron FC5
    V3
    Something to add:
    Swiftech 655 pump is working at
    Nominal voltage 12 V DC
    Nominal power (@ 12 V) 24 W
    Nominal current (@ 12 V) 2 amps
    Therefore you need a digital fan controller min 25 watt to control it over fan controller.
    But to see only the speed of the pump,you cann use any digital fan controller.
    T o do this you must add the yellow tacho cable of pump , to the yellow tacho kable of fan controller.
    That is all.
  11. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    The last tubings between pump-midplate-and 240 monsta done .
    Pump isoliert
    The bottom chamber is red illuminated. And controlled with a dimmer from panel , to vary the brightness of a light . I want a dark room..
    You can dimm
    Darker
    And darker
    And darker…
    And you can shut of.
  12. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    update 19/08/2014
    recent addıtıons to the case…
    There is a problem on most Mainboards if we cool it with MB Waterblock…
    You must see this image
    İnstead of the BLACK BEAUTY of rampege 4 extrem black edition.
    I think , ıt is one of the best design
    I planned to use the original cooler of the MB but painted .
    But it was not all … cooler does not cover all the metal look . there is 5-6 mm space
    between EL I/O shield and cooler .
    therfore ı mounted an U shaped 2mm black plexi ,
    and then mounted the cooler.
    the results
    UPDATE 20/08/2014
    My firend wanted to see some logos on his Case.He likes the logos… I draw 3 logos for the case. And laser cutted all together. but the pieces were too small and there was too many parts.
    I came home with a great plastic bag
    Took quite long to classify..
    A Repuclic of gamers logo (relief) and illuminated
    And special logo for my friend to SLİ bridge .
    his name is Salih SakSAK , I made a logo from the first letters of the name… SSS
    (relief) and illuminated .
  13. hanssx2
    hanssx2 Minimodder
    1 May 2014
    It is getting together :)
    looks pretty sweet :drool:
  14. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    update 20/08/2014
    And a special CORSAIR logo to Corsair Case (Just finished)
    As signature…
    Sails in relief…
    staged from the far away to the nearest
    from small sail to the large..
    .from left to the right..
    .to give full sail effect.
    Of corse illuminated
    At my next corsair logo i ll try to make it relief and cambered… arg-ist
  15. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 03.12.2014
    Sorry...
    lately I neglected to add photos for this worklog. There are some photos before filling fluid
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Very nice of you to show how to make something like that :thumb:
  17. Hanoverfist
    Hanoverfist What's a Dremel?
    11 May 2014
    Interesting Design. I too like the Presentation you have here. :thumb:
  18. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    update 16/07/2014
  19. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 25/07/2014
  20. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    nice pump mod, thanks for sharing :D
