Hardware Samsung 32GB Solid State Drive
Discussion in 'Article Discussion' started by Tim S, 21 Jul 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. konsta
    konsta What's a Dremel?
    2 Jul 2005
    I'm relatively certain that we've been using rotating glass disks to store our data for quite a long time now...
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    /me looks forward to larger, faster, cheaper ones in around 2 years time :)
  4. Guest-16
    Guest-16 Guest
    Well metal surface, Konsta. :p
  5. hughwi
    hughwi Minimodder
    23 Dec 2003
    Whilst those results are a little underwhelming, this looks rather promising for the future :D
  6. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Did I miss it or were there no power usage tests? That'd be nice to see imo specifically in our more power concious society :)
  7. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    yeah power consumption would have been nice, does look promising for the future
  8. Guest-16
    Guest-16 Guest
    No real point on a desktop system since it was designed for a notebook. We were testing it as an alternative for performance, rather then something for a low power solution. I may throw it in the EPIA testing I'm doing at the moment to see if I can get a really really low power desktop.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    How would you accurately measure the power usage of a device with no power lead? ;)
  10. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    - The laptop to standard PATA adaptor that I presume has been used would split the drive's connector to 40 pin IDE and a standard molex...
    Mine does at least....
  11. Guest-16
    Guest-16 Guest
    Yep, but in a desktop system just changing the CPU, graphics card or motherboard type will completely negate any effect of a single hard drive. In a 30W EPIA system it can make a significant difference to heat, noise and power.
  12. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    measure power usage of whole system with ssd in and then again with raptor and the seagate you used in the review
  13. Morphes
    Morphes What's a Dremel?
    30 Nov 2004
    I bet this would be amazing in a 360, I really am curious to see the review for the notebook
  14. Nature
    Nature Minimodder
    21 Nov 2005
    I'm not sure but "trusted reviews" did an article on this and I think by Mr. Swinburne (strange how he recycles..). In it, was a 6 to 8 page briefing on the note book preformance of this piece of korean hib-hob.
  15. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    It was done by Riyad Emeran TR's editor-in-chief... Rich had nothing to do with it...
    The SSD fitted Vaio review will be available HERE on Monday when the link becomes active.
    The non-SSD review is HERE
  16. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Some disks still use metal.
    but the glass ones make a cooler noise when a laptop is dropped 6 meters.. :D
  17. Guest-16
    Guest-16 Guest
    Ed Chester did a TR review of it a few weeks ago, I'm doing a different review of it now. Someone at TR is doing the SSD Sony (different SSD in it) review for Monday. No recycling done.
    And any chance you could spell my name correctly, it IS there under 20,000+ posts. :)
  18. Nature
    Nature Minimodder
    21 Nov 2005
    Oh, I see. I Just remember Mr. SWINburne's name written on the article...
  19. provoko
    provoko What's a Dremel?
    21 Jul 2007
    Yea, thats how it's usually done. Also test for heat on idle and load.
    I was expecting these tests. Lots of people make silent PCs and HTPCs and are really hoping SSD draw little wattage and produce little heat, so knowing actual numbers would be nice.
    Will you guys update the article?
  20. Guest-16
    Guest-16 Guest
    They will be in the EPIA review.
Tags: Add Tags
