News Samsung announces 24" LED-backlit LCD panel
Discussion in 'Article Discussion' started by Tim S, 12 Apr 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    Small baby steps, and we'll make it to semi-infinite contrast ratios.
  3. Tim S
    Tim S OG
    8 Nov 2001
    yep, I think Samsung has licensed BrightSide's technology, but I don't think this is based on that technology. I guess we'll have to wait a bit longer before we see HDR PC monitors. :)
  4. DougEdey
    5 Jul 2005
    this guy made an LED backlight for his LCD, personally I don't think it's too great in terms of brightness (admittedly he had a couple of LEDs die) but I hope Samsung do a far better job.
    Also, haven't Samsung had LED backlights in their Plasmas?
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    isn't this just a panel that uses LEDs in place of the CCFLs at the edges of the screen?
    i mean, sure, it will have better colour and be longer lasting but i don't think that makes it have anything in common with brightside, which has a matrix of LEDs covering the rear of the panel
  6. RTT
    RTT #parp
    12 Mar 2001
    Nice :D Having seen LED backlit notebook displays no doubt these will catch on quick when they hit the market
  7. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Ooh I may get a couple :)
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    I bet they will as the power usage has got to be lower for an LED based screen!
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Plasmas are active displays. They don't use backlights.
  10. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Looks quite nice and the potential power-savings in notebook is very welcome but I'm still waiting to see the HDR displays, they're gonna be great! :)
  11. Nexxo
    23 Oct 2001
    Sony already have LED based LCD laptop screens, and they are indistinguishable from CCFL-lit screens. The advantages are reduced heat and power consumption, and longer life span. They are also more resistant to damage.
    A mod works better, of course, when you use a dense strip of high-brightness white micro LEDs.
    Plasma screens, as pointed out, do not use backlighting as the pixels generate their own light. OLEDs do the same.
  12. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    any word on price, makes me wonder if I should get a basic monitor when i upgrade
  13. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    This doesn't really have much to do with LEDs...
    The contrast ratio is really all about the panel, and so is the viewing angle.
    Looks pretty cool though.
  14. Tim S
    Tim S OG
    8 Nov 2001
    Not necessarily... how does the BrightSide manage a 200,000:1 contrast ratio? It's because of the backlight... the panel is the same as the one sitting right next to it in the Westinghouse display here: http://www.bit-tech.net/hardware/2005/10/04/brightside_hdr_edr/1.html
  15. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    So will LED backlighting do away with 'backlight bleed' in lcds and plasmas?...
  16. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    With blacks so dark it literally sucks the photons out of the air, and whites so brilliant you would be better off staring at the sun :D
    111% of colors is good, but no doubts its going to cost an arm and three quarters of your left leg.
  17. rupbert
    28 Jul 2002
    I'll have 2 then! :D
  18. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    You have 2 left legs ?
  19. DougEdey
    5 Jul 2005
    I can haggle that down to half an arm and a hobo.
  20. Veles
    Veles DUR HUR
    18 Nov 2005
    I think a three quarters of your right leg is also acceptable payment
Tags: Add Tags
