News Samsung expands its Odyssey Gaming Monitor lineup
Discussion in 'Article Discussion' started by bit-tech, 21 Jun 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. grimerking
    grimerking Minimodder
    26 Apr 2009
    The curved models offer 240Hz. Why have these screens reduced that to 144Hz?
    monty-pup likes this.
  3. monty-pup
    monty-pup Minimodder
    8 Apr 2018
    I’m think as soon as Samsung release a monitor that doesn’t have a load of GSync users screaming about flicker, and it’s 1ms response and 240hz+, and 32”+ …. I might be upgrading.
    Apparently they might have fixed the G7 32” flicker issue, but I’d rather buy something newly released that didn’t have that issue in the first place, and require a firmware ‘fix’.
  4. grimerking
    26 Apr 2009
    I have the G9 and I think the flickering is quite a specific scenario - Freesync + HDR. The HDR on this monitor is so dark, that I never bother enabling it. Freesync also seems to be buggy and I've had issues in Warzone where the frame rate drops to one frame every 3 or 4 seconds instead of the 120fps I normally get.
    Due to these problems, I've set my monitor to 240Hz without HDR or Freesync.
    IMHO the bigger issues with the G9 are:
    • Lack of USB-C that could be used for:
      • laptop charging
      • display
      • connect the USB hub on the monitor. .
    • No desktop control software to switch display inputs, monitor profiles, etc.
    • Split screen doesn't allow you to have one input in the middle of the screen with other inputs at the sides.
  5. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Copy/paste from sales brochure? Ad-driven article?
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    With the mountain of issues HDR has on Windows 10 it wouldn't be worth the hassle regardless of what the monitor does anyway.
Tags: Add Tags
