So I would like a nice new monitor, preferably a 1080p one so it doesn't go all screwy with my xbox's aspect ratio, and these are the two I've looked at. The Viewsonic has been recommended as a great budget monitor here several times and is available on eBuyer for only £140 now. I've also seen it in action and thought it was pretty good. The F2380 is a bit swisher (although still not knock your socks off good) down to the fact it's not a TN panel but £60 more expensive. I believe it's also slightly larger physically. I'm currently using two poor quality £80 budget Samsungs that were bought several years ago and are now in need of replacing, they're fuzzy and images burn into them very easily. I was going to get the Viewsonic a while back but decided to save my money, and bearing in mind the £60 difference in price is currently almost half of my monthly wages, I'm leading towards the Viewsonic which would still be a massive improvement over what I'm using now (which I have managed to put up with quite easily for several years).
It depends what you're going to use them for. If you're at all interested in gaming then the F2380 is definite no-no! If you don't want to try an IPS panel (Dell2209wa) then Viewsonic's 120hz vm2268wmi is a great choice for a TN panel. But don't take my word for it... http://www.digitalversus.com/duels.php?ty=6&ma1=41&mo1=439&p1=4273&ma2=36&mo2=607&p2=6954&ph=1 An alternative site is this one... http://www.tftcentral.co.uk/ Use the tft selector, top left.
