Samsung monitor is not recognising my Asus Strix 1050Ti GPU
Discussion in 'Asus UK' started by decebal_12000, 9 Oct 2017.
  1. decebal_12000
    decebal_12000 Member
    13 Aug 2009
    Hi. I have this monitor Samsung LS27E510CS and I connected to my PC through HDMI but it doesn`t come on at all. MY GPU is an Asus Strix 1050Ti and my motherboard is an Asus Maximus VIII Ranger.
    I tried to connect through DVI and also I do not have any picture from my PC. I reinstalled the WIndows 10 and I have the drivers but nothing yet.
    I connected to a different PC with an Asus 960 GPU through DVI and it works there.
    Does anyone knows why happens? I bought the monitor from someone and he claims it works on his 1060 GPU.
  2. Will_ASUSUK
    Will_ASUSUK New Member
    20 Jun 2016
  3. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    You haven't got your motherboard set to use the IGPU have you?
  4. decebal_12000
    13 Aug 2009
    I tried different cables and ports but I had the result, no output. I did not do DDU but I reinstalled the Windows and clean install the Nvidia driver.
  5. decebal_12000
    13 Aug 2009
    I don`t think so but I will have a look when I will go home later.
    Does it affect the output of the video signal?
  6. TheMadDutchDude
    23 Aug 2013
    You're definitely using the GPU outputs and are not connecting it to the motherboard, right?
  7. decebal_12000
    13 Aug 2009
    I do not use the motherboards`s HDMI to connect the monitor. I have 4 outputs on GPU and I tried all but the monitor is not detecting anything.
  8. CrapBag
    17 Jul 2008
    If you have the setting in the Uefi set to onboard only then you won't get any display from your card.
    Connection to an onboard output and check-in the bios, at least you can rule that out then.
  9. decebal_12000
    13 Aug 2009
    I have another monitor which is working on that HDMI but this monitor has something which doen`t like on my PC.
  10. decebal_12000
    13 Aug 2009
    I sorted. I returned the monitor as wasn`t compatible with my motherboard.
