Memory samsung ram
Discussion in 'Hardware' started by xxxsonic1971, 20 Nov 2012.
  1. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Hello,
    Will this ram run in an x79 mobo without any issues? --Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US) [MV-3V4G3D/USx2]
    Many thanks!!!!
  2. rollo
    rollo Modder
    16 May 2008
    If green still stands for economy ram then your better off buying another type of ram. 16gb is pretty cheap though at the min in most of the major ones.
  3. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    This Samsung stuff is meant to be pretty damn special, as it's made on a 30nm process so allows for very good OC's or some such. And yes, I don't see any reason why it won't run without issue, correct me if I'm wrong.
  4. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    This TechPowerUp thread is basically the anectodal encyclopaedia of this Samsung memory. From what I can recall, the general consensus is that you can buy two unmatched pairs and they will work in quad channel. In fact, this memory seems to put its best foot forward on the X79 platform with some of the best OCs being achieved on the Sandy Bridge E platform.
    With regards to motherboard compatibility, it never hurts to check the QVL that each motherboard has listed on its website, but these sticks should present nothing out of the ordinary.
    edit: Just noticed that you are referring to the quad channel kit, they weren't available when I was researching the RAM. The fact that they come as a set should be an extra reassurance that they will be compatible with each other and with your motherboard.
  5. jizwizard
    jizwizard Modder
    24 Dec 2010
    Far from being economy ram. I have this running at 2400mhz on my rig at 1.55v
  6. xxxsonic1971
    5 Dec 2010
    Thanks all, samsung ram it is then! The low profile and the name samsung is the deal maker for me.
  7. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    I have 16Gb too. Insanely low profile, almost looks like you forgot to install it. And hits 2400mhz easily.
