Hardware Samsung SM2693HM 25.5" widescreen
Discussion in 'Article Discussion' started by Tim S, 1 Oct 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. clumsy_culhane
    clumsy_culhane Minimodder
    4 Dec 2007
    "The viewing angles are very ordinary with fairly epic colour inversion taking place at even moderate angles. " Nice statement. I for one am still on a 21" inch CRT, and still loving it. I got it for $80 Australian and it has great constrast, good colours (with calibration of course).
  3. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    If you were looking at a flat screen for photography, you'd be looking at an XL20 LED or NEC's equivalent anyway.
  4. clumsy_culhane
    4 Dec 2007
    Yeh.. which i can't afford.. which is why I'm sticking with CRT's till LCD's get better.
  5. kylew
    kylew What's a Dremel?
    28 Apr 2007
    Ugh people have been saying this rubbish since LCDs were first mass produced. TN panels are poor, but PVA aren't. I use TN screens at work and the colour inversion is annoying, but my 24" screens at home are dell 2408s, they suffer from no noticeable colour inversion and are far superior to any CRT I've used. LCDs were terrible when they were first put in to mass production, but they have improved a massive amount since that people can't honestly still be saying 'I'm waiting until they improve' because you think they're poor.
    I can't stand using CRT monitors due to the headaches they give me. But people need to stop clinging on to the 'until LCDs get better' because they're already much better than CRTs outside of the most picky 'problems' such as 'input lag', that your average gamer convinces themselves that they are so good at gaming that they need a CRT (and an 8000DPI mouse :rolleyes:) to 'enhance' their performance because they're so unbelievably good already.
  6. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    I have a 20" LG L206WTY and I have zero color inversion when viewing from the side. I have no clue what type of panel it uses though. But it has none of the issues that most people complain about LCDs. With a 2ms response time things stay sharp when in motion. I had a 17" Sammy with an 8ms response time before this one and the difference was incredible.
  7. Silver51
    24 Jul 2006
    No, I understand what he means, I stayed with a CRT for years. For me, the cost of upgrading to LCD was the XL20 because I didn't want to compromise on colour. Standard gaming LCDs still aren't as good as a pro CRT in this respect, although this is my opinion and I'm open to having my mind changed.
  8. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    i was so disappointed with my 19" SM 940BW, and kinda still am. I got used to it, then i got a Dell 2007WFP, on an IPS panel, and i dont think i could spend money on a TN+Film again, the image quality is SO much better on the dell.
    what i'm waiting for, is a decently priced 24" 1920x1200 IPS based panel ~£350
  9. Horizon
    Horizon Dremel Worthy
    30 May 2008
    Note to anyone considering buying that monitor, it does not come with the built in usb ports, they are optional and listed as so in the manual.
  10. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    Um, the reason so many monitors are sticking with 1920x1200 most likely has little to do any choice on the vendors' parts. It's down to single-link DVI being most prevalent. To drive a higher resolution that isn't oddball[1], you need DVI-D or HDMI.
    [1] "1915 x 1436" quoth Wikipedia - however that's pretty much an impossible resolution, as there are wide assumptions of of a 8-divisible strides for screen buffers.
  11. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    The Iiyama ProLite E2607WS 26" (the HDMI one) can be had for about £280. I'd say thats a pretty direct competitor. Any opinions on which you'd chose?
  12. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I have read almost all LCD reviews on BT and in the 4 or 3 years there is not one LCD that was good in displaying colors. I switch regulary to a old CRT monitor to edit gradients and choosing the right colors because the Dell LCD's (E196FP made in 2005) I use are too "bright" on the normal viewing angle. I have to view it from below the tabletop to actually see the right color darkness.
  13. Rich_13
    12 Feb 2003
    Anyone got any other monitors they'd suggest, i'm looking around the £300 mark and these are the only real 2 I've considered..
  14. bothaus
    bothaus What's a Dremel?
    4 Sep 2008
Tags: Add Tags
