Storage Samsung Spinpoint Failure rates
Discussion in 'Hardware' started by Baz, 1 Mar 2011.
  1. kenco_uk
    28 Nov 2003
    2 x F1 1TB have been in my rig, one as Vista, other as games and programs. Then in a Nas in raid0, now in another pc - one as Windows7 sys and other as backup/files.
    2 x F2 1.5TB in my rig currently, used as backup, games and program drives.
    I can't remember when I bought them, sorry but the 1TB drives have been in service for acouple of years or so and the 1.5's have been in use about a year or so maybe longer.
  2. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Speak of the devil... I just lost two Spinpoint HD103SJ's today. They started dropping out of Windows randomly, and then all of a sudden stopped showing up in BIOS. I think I just got a bad batch, their serial numbers are sequential and they both chose to die together.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    What is the firmware version of them?
    See this: http://forums.bit-tech.net/showthread.php?t=203661.
  4. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    3 x F1 500gig (used as main drive) all died within 2 years
    2 x F1 500gig (used as storage drive) still going.
    4 x F3 500gig (2 used as main drive / 2 as storage) + 1 x F3 1TB (storage) all going strong for minimum of a year.
  5. Skellig
    Skellig New Member
    2 Mar 2011
    Been buying F3 HDs recently. I really hope I haven't got a bad batch but I reckon their failure rates are pretty damn low as hard drives go.
  6. 8 Bit Charlie
    8 Bit Charlie New Member
    9 Sep 2010
    I've got 2 1TB F3s, One as my main drive, the other in the sky box getting fairly constant use. Had both for approx 14 months and not had any problems yet.
  7. sheninat0r
    28 May 2007
  8. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Crystal DiskInfo will show the firmware version. The zip file doesn't need an installation.
  9. Fingers66
    30 Apr 2010
    If they won't show in the BIOS, you won't be able to see the firmware version as it is not written on the outside.
    If both won't show in the BIOS, are you sure the m/b, SATA & power cables are okay? Do you have another machine you can test it on first?
  10. Altron
    Altron Well-Known Member
    12 Dec 2002
    Had a couple of the original Spinpoints. A 120gb and two 250gb. The 120 and one of the 250s are still working fine, more than 5 years (got the 250 in late 2005, and the 120 in late 2006). The other 250 died after 3 years (bought in early 2007, died around xmas 2009).
    As for the new ones, I bought a pair of 1TB F3s in the summer (one in May, one in July). One of the drives failed in November. I was moving cases and when I re-installed it, it just had the "click of death". I took the usual safety precautions, and it wasn't mishandled, so I'm not sure if it was a normal failure or if something weird happened when I was moving it. I RMA'ed it, and the replacement is chugging along like a champ.
  11. Grimloon
    Grimloon New Member
    4 Sep 2008
    1 x 1.5 TB F3, 8 months old or so. No problems at all, very quiet too.
    Actually, the only drives I've ever had fail on me were all WD Caviars.
  12. craigr1982
    craigr1982 New Member
    29 Jun 2006
    2x 1TB F3 - 8 months old - On 24/7, media streamer pc.
    2x 1TB F1 - 18months (I think), Desktop PC.
    2x 750Gb - 2 years constant use, now relegated to backup devices
    1x 500gb, 1x 320. Ancient. still used
    No issues on any of them.
  13. frontline
    frontline Punish Your Machine
    24 Jun 2007
    1 x T166 500GB HD501LJ - around 4 years old, working fine
    2 x 1TB F1's - about 6 months old, working fine
    Pretty much spinning up 24 hrs a day until recently, when i started shutting down the PC overnight.
  14. Tech NoOb
    Tech NoOb New Member
    12 Feb 2011
    1TB F1 2 years old - no issues
    1TB F3 1 Year old - no issues
    2TB F4 2 months - no issues
  15. wbdog206
    wbdog206 not me
    15 Jan 2007
    I have a 1TB F1 grinding away as a networked file server.
    Has been running fine 24/7 for about 2 years with no problems. Knock on wood.
    I have only had 2 drives drop dead on me in the last 8 years
    one was a W\D caviar and one was a Hitachi Deathstar.
  16. Carl Marten
    Carl Marten Forget Dremels, buy angle grinders.
    24 Apr 2009
    After recomending them to friends (well puting them into their builds) and using at least 40 Spinpoints I was shocked to blow 6 drives in as many months in my own system.
    Turned out to be a faulty PSU that was spiking the 12v line (had checked it before with my trusty analogue multimeter but the spikes only showed on digital).
    Lost soo much hardware to that PSU.
  17. urobulos
    urobulos Member
    13 Apr 2010
    2x 1TB F3s. 1 is around 8 months old, the other around 5-6. No issues so far.
    Only component that ever broke down in my PC was the Corsair HX850 which blew up after 3 months of light use >.>
  18. Aracos
    Aracos New Member
    11 Feb 2009
    F3 500GB 1 year and 1 month or so old. Working perfectly.
    F3 1TB in an icybox enclosure connected via eSATA 1 year 6 months old working perfect but one night win 7 decided to really thrash it to death, quick reboot sorted that though.
  19. cdb
    cdb No comment
    25 Apr 2009
    2 F3 1TB in my machine. 16months old and still working.
    It was running 24/7 until last month, so at least the one with the o/s on it will have had above average use.
  20. rob the bank
    rob the bank New Member
    13 Mar 2010
    Over the last 3 years have used around:
    1TB Samsung = 2000 dead in warranty around 25
    1TB Hitachi = 800 dead in warranty around 8
    1TB WD 64mb Cache = 4500 dead in warranty around 60
    1TB Seagate = 500 dead in warranty around 2
    Although worse drive is WD 160gb 10K Raptor used 8 dead in warranty 6
    So we see a couple more WD 1TB die then average but all others pretty much the same.
    Obviously these are not all personal use :=) i work for a custom PC builder.
