News Samsung tapes out first 14nm FinFET-based parts
Discussion in 'Article Discussion' started by Gareth Halfacree, 21 Dec 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. barny2767
    barny2767 What's a Dremel?
    27 Sep 2011
    Im hoping that since GlobalFoundries is involved in this AMD will be able to jump on FinFET and 14nm production before Intel realy gets its Tri-Gate in to production as this may give AMD the boost they need to put out low power or higher performance chips
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    "Sadly, a tape-out does not a product make" should be "Sadly, a tape-out does not make a product".
    Anyways, getting the chips smaller, resulting in less powerdraw is all nice and dandy, and I hope that the industry can keep their set goal of Q1 2014 for those 14nm-parts.
    Unfortunately the real power-hungry parts - aka the GPUs - are still manufactured in 28nm and won't see a shrink that soon, if we believe all the chatter.
    intel - if all goes as planned - will start with their new plant in Arizona in Q3/Q4 2013. I don't think that AMD will be faster than this.
  4. Alecto
    Alecto Minimodder
    20 Apr 2012
    "lithographic processor"
    process perhaps ?
  5. Alecto
    Alecto Minimodder
    20 Apr 2012
    Dafuq ?! Intel has been using "TriGate transistors" in its Ivy Bridge and will be using them in the upcoming Haswell and onwards.
  6. Gareth Halfacree
    4 Dec 2007
    No, it shouldn't: I wrote what I meant and I meant what I wrote.
    That, on the other hand, was a mistake. Fixed, ta!
  7. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    Exactly. Intel is looking at 14nm roughly sometime in early 2014. Unless the other fabs manage some serious catch-up work, they are going to be looking at late 2014 in to 2015 before they manage that.
    Other than NAND, for processor transistors most have not gotten below 28nm yet and I really doubt they are going to skip a full node. Most are looking at transitioning to 20nm sometime in 2013 (probably late 2013 or early 2014).
    General cadence industry wide is about 2-2 1/2 years per processing node shrink, Intel just happens to be roughly 18-30 months ahead of most everyone else with lithographic size.
  8. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    and unless somebody comes up with 80bn, thats how it's gonna stay
  9. technogiant
    technogiant What's a Dremel?
    2 May 2009
    Well a smaller process size and trigate/finfet transistor architecture didn't really work out to be "all that" for Intel in the change from Sandybridge to Ivybridge. Only gave a 27% improvement in tdp from 98w for SB and 77w for IB at the same performance level not the quoted 50% improvement and that was not just due to the finfet design but also include a shrink to 22nm.
    IB's thermals are poor...I don't think Intel have either their 22nm process or trigate design right yet.
  10. rollo
    rollo Modder
    16 May 2008
    14nm is at least a year away from intel more like 2 from anyone else.
    Taped out does not mean its ready to go into full scale production, intel already has a working 14nm chip, will take at least 2 years from tapes out to full scale.
    AMD can't just switch from tmsc they have long term contracts.
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    Ah OK. Not a native speaker so it looked awkward to me :p
  12. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    You are quite right that it does look weird, so it is good that you can spot things like that, but it is actually a semi-commonly used phrase.It's just bad luck on your part this time.
  13. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    the first one, he was being Yoda ;)
