Modding Sanding beige comp sides
Discussion in 'Modding' started by bard, 3 Apr 2003.
  1. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    I have a lot of computers under my bed :lol: which I don't really use (the computers, mind you!). I am thinking of modding one or two. The sides are made out of metal, which is beige/off white. Can I use a sander and sand it down to the metal, and cover it with some kind of clear coat, and the I'll have myself a nice little "aluminum" case? (Of course, I would have to make a new bezel). Suggestions? Advice? Anything? Huh?:rolleyes:
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    yeah... I actually did this for a system I made for my cousin. I used round sanding disks that mounted on my cordless drill. Gave it a swirly brushed look... my wife did this for a table she made out of engineering drawers. The clearcoat is highly suggested as not only is the steel is exposed but if you give it a rough sand like I did, the added surface area will promote rust to form even faster than normal.
    We also used a wire brush wheel attachment on the drill and that had some neat effects..
  3. bard
    8 Mar 2003
    I guess I'll give it a try, then. Is it ok to use a flat sander? (don't know what they're called in English? Should I just use the wirebrush in the end? What kind of clear coat do you recommend?
  4. eddie_dane
    31 Jan 2002
    yeah, a flat sander (sanding block) will work fine... those are good to get a "brushed" look.... use some coarse grit paper and sand it in a straight/uniform direction and get some nice effects to... just a lot more work. I used Rustoleum clear coat, worked well for me but geography dictates what you have availabe to you're specific area.
  5. pranks7er
    pranks7er mange tout
    25 Dec 2002
    why dont you get a strong paint remover and try that
  6. eddie_dane
    31 Jan 2002
    paint remover would be a good shortcut but I get the impression from bard that he is seeking a "finished" metal look too.
