News SanDisk launches 240MB/s USB flash drive
Discussion in 'Article Discussion' started by Gareth Halfacree, 12 Feb 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
  3. theshadow2001
    3 May 2012
    Is that a wodge of storage in your pocket or are you just happy to see me?
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Not sure I would be happy to carry that around, USB sticks are so easy to loose
  5. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    I'd rather go with a eSATAp (powered) adapter ($6 from china) and a regular SSD. Some of the SSD PCB's take up such a small space that you could easily hack it into something much smaller than a standard 2.5" case.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you need compact then make sure you have a smartphone with a removable battery, the battery compartment is usually big enough that you can use it to store one or more extra microSD cards.
