Hardware SanDisk Ultra Plus 256GB review
Discussion in 'Article Discussion' started by brumgrunt, 28 Jan 2013.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    The most interesting thing in these results, to my eyes, is the OCZ Vector's results in BootRacer. They've probably been in past reviews, but this is the first time I saw them.
    Single-task benchmarks like sequential and random read and write clearly don't model the boot process well. That's a mix of random and sequential reads and writes. The drives are black boxes containing cache and logic; probe them with such simplistic tests, and it's reasonably easy for the logic to detect the test, and optimize cache for that use case. Assuming the logic can do this, all the benchmarks are testing then is the raw speed of the underlying hardware. The smartness of the logic itself is not being tested.
    For example, in a read benchmark, no cache need be reserved for buffering writes; and vice versa.
    But real-world use cases have a mixed set of reads and writes, of varying sizes. That's where the real test of the logic comes in. The logic needs to make hard decisions about how much cache to keep spare, and which to spend on optimizing reads vs writes. And it's likely that one drive which is best for boot times won't be as good as the best drive for launching apps, and that won't be the best one for a database cache.
    We need better benchmarks. These benchmarks are too easy to game, and risk rewarding market to inferior products.
  3. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    A prime SSD for modding and use in tiny builds methinks!
  4. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    Well, that and the photo showing that a 250Gb SSD fits in only a third the space of a standard 2.5 inch drive area!
  5. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    So much money for a 3cm x 6cm strip of electronics inside a large empty box....
  6. Baz
    Baz I work for Corsair
    13 Jan 2005
    And yet it's competitvely priced. I remember when the first round of SSDs came out in 2008/9 and they were worth close to their weight in gold. Mental, but then look at CPUs! almost nothing to them, but some are worth Thousands. its what it can do you for in the that you pay for, not what it is.
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Makes you wonder why mSATA is so much slower....
    That and it would be cool if you could plug this guy directly too your motherboard.
  8. toolio20
    toolio20 What's a Dremel?
    29 Jan 2011
    Whoa whoa whoa, wait...what TRIM "command" is the author referring to on the second page? I thought TRIM ran somewhat automatically, cued up when files are permanently deleted...some clarification would be greatly appreciated!
  9. haggisathome
    haggisathome What's a Dremel?
    1 Oct 2003
    thats what i was thinking , for what it is its tiny ... runs off to open up my 60 gig ssd to see if its the same :naughty:
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    you can force windows to run TRIM, just as using SSDTweaker can disable it -which is exactly what was written on page 2
  11. Acanuck
    Acanuck What's a Dremel?
    17 Mar 2011
    Not to be a grammar Nazi or anything, but the sentence:
    "first allowing five restarts to allow Windows 7 to get it's caching together"
    under the BootRacer section, should read
    "first allowing five restarts to allow Windows 7 to get its caching together."
    Otherwise, sound review. Glad bit-tech take benchmarking so seriously.
  12. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Good spot! Fixed now, cheers.
  13. toolio20
    29 Jan 2011
    Ahhhhh, page 2...yessss, I see now. I jumped straight to the "TRIM" section on the summary page. :duh: Thanks for the asked-for clarification!
Tags: Add Tags
