Sandy Bridge Rackmount Build
Discussion in 'Watercooling' started by musicjerm, 30 Jan 2011.
  1. musicjerm
    musicjerm What's a Dremel?
    25 Jan 2011
    My new Sandy Bridge rackmount build (pre-liquid cooled)
    Lian Li PC-C32B Case
    Antec 1000 Watt Power Supply
    ASUS P8P67 Deluxe Motherboard
    Intel Core i7 2600k Processor
    Corsair 8GB DDR3 1600Mhz Dominator Memory
    EVGA GTX 480 (Return RMA from a GTX 295 :))
    Intel X25-M 80GB Solid State Drive
    Intel X25-M 160GB Solid State Drive
    I would like to do a chiller under the system or find a good rackmount solution with radiators. I also have a second GTX 480 but don't think I'll take advantage of SLI so it probably won't end up in this build. I've really had a hard time trying to figure out how to chill this system and have it look good. I wish Hailea made chillers that just slid right into a rack :) If anyone has any ideas I'd appreciate it.
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    I think you Should Attach THIS inside/ to the side of the rack ;)
    That would be all sorts of epic :thumb::rock:
  3. musicjerm
    25 Jan 2011
    I was actually looking at that. Do you happen to know if the radiator stand is rack-mountable? The dimensions seem about right...
  4. aquatuning
    5 Jul 2006
    it was not designed with that in mind im afraid but if its the right size mod it :p
  5. Guest-16
    Guest-16 Guest
  6. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    You sure that Quiklok rack/table is a standard 19" wide (internally)?
    It looks like one of these to me: http://www.quiklok.com/catalog/?p=productsMore&iProduct=469&sName=Z-612
    Love it by the way! :thumb:
  7. musicjerm
    25 Jan 2011
    It is a standard 19" rack but from the inside of the mounts it measures 17.75 inches or roughly 45cm. the width of that stand is 42cm so I'm only off by 3cm - That should be no problem with some rackmount ears and a little bit of modding :) If anyone has a better idea I'm open for that as well... Thanks for the comments too!
    I also forgot to mention the handywork of my buddy Mike who cut the window into my side panel. He did a great job!
  8. musicjerm
    25 Jan 2011
    Alright here is the liquid cooled product.
    Liquid Components Used:
    EK HF CPU Block
    EK GTX 480 Block
    EK Radiators (2 x 240)
    Swiftek D5 Pump with EK Top
    Koolance Quick Disconnects and Compression Fittings
    Tygon 1/2" ID Tubing
    Feser UV Blue Fluid (still need to add UV lighting)
    This system was built at our Local A to Z Computers here in Riverdale Utah.
    Thanks to my co-worker Mike for his help with the window and some minor case/psu mods.
  9. Fingers66
    30 Apr 2010
    With those rad fans on the outside of the case, what is the noise like?
  10. musicjerm
    25 Jan 2011
    Noise lvls are very low. Its almost completely silent. The only fan I can really hear is the PSU fan. Temps are also very cool about 50c under a full load. Overall I am very happy with how this build turned out.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    This is a mint build. Genuinely impressed.
  12. Matticus
    Matticus ...
    23 Feb 2008
    This. Great work!
  13. musicjerm
    25 Jan 2011
    Thanks!
  14. Guest-16
    Guest-16 Guest
    Beautiful build! Makes me want a rack myself now.
    Are those external connectors disconnectable without spillage?
  15. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    One of the best classy watercooling builds I have seen, great to see someone doing something a bit different.
  16. musicjerm
    25 Jan 2011
    They worked without spilling a couple times but the female ends no longer seal, so what I think I'm going to do is get a couple spare male ends and make a "U" to close the seal on the female ends when I'm transporting it.
    Thanks again for all the comments. I posted this build on a couple other forums and this is the only place that really seams to care.
  17. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Top notch stuff :) What kind of temps are you getting?
  18. musicjerm
    25 Jan 2011
    GPU sits at about 60c when I'm gaming, cpu is around 40c
    Running fur mark and prime95 for a couple hours the GPU hit 70c and the CPU hit 66c, that is while gpu is clocked to 850mhz (stock 700) and cpu running at 4.8ghz (stock 3.4)
  19. Guest-16
    Guest-16 Guest
    Because bit is awesome <3
  20. Guest-23315
    Guest-23315 Guest
    Stuff like this seriously makes me consider getting a rack for my next set up - Great way of combining all my PC and guitar gear. Also, the idea of building up a dedicated HDD rack and fully isolating it all is seriously temping.
