Build Advice Sandy Or Bulldozer
Discussion in 'Hardware' started by james888, 17 Jun 2011.
Bulldozer or sandy Bridge?
  1. Bulldozer (Amd)
    5 vote(s)
    26.3%
  2. Sandy Bridge (Intel)
    14 vote(s)
    73.7%
  1. james888
    james888 New Member
    13 Mar 2011
    In the final thought of choosing what I should build.
    Should I go with the Sandy Bridge with p67...
    or...
    go with the 990fx and be prepared for bulldozer?
  2. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    I don't think you can make this decision really until bulldozer is released.
    It shouldn't make a difference waiting a couple of months as nothing is going to be replacing SB anytime soon.
    HOWEVER, if you are currently running an AM3 rig then buying a new AM3+ board now and waiting for bulldozer does create the easier upgrade path and save you from shelling out a lot of money in one go.
  3. Whindog
    Whindog New Member
    16 Sep 2010
    Sandy bridge is as fast as any1 will ever need. OC it to 4.5Ghz+ and your set for life.....essentially.
    Unless off course your a pro video encoder or whatnot. For everyday use & gaming, you will never need faster than sandy bridge for a very long time.
  4. azrael-
    azrael- I'm special...
    18 May 2008
    ^ This. Bulldozer is an as yet unknown quantity, so you'd have to be a die-hard AMD supporter to choose Bulldozer before it is even available. In any case you might be lucky enough that when BD launches in a couple of months it may drive down prices on SB, if you choose to go down that route instead.
  5. chrismarkham1982
    chrismarkham1982 Well-Known Member
    1 Apr 2010
    have to agree with all the comments here, sandybridge is as fast as youll need for a while but bulldozer is nearly here and it could turn out to be blindingly brilliant BUT i have a hunch i wont be brilliant at all (well it might be compared to core 2 or phenom 2) they keep putting it back because of various issues and it makes me wonder if perhaps they are trying to push the chips to much already? of course i could be completely way off the mark just my thoughts thats all, if you were looking to buy straight away then your only option is sandybridge as it blows everything out of the water.....for the moment
  6. adam_bagpuss
    24 Apr 2009
    buying into a platform not even yet released or reviewed is a poor decision
    so you have 2 choices wait for bulldozer and check the performance or buy SB now
  7. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Agreed, investing in BD at this time is unwise. The reality is that SB is currently the proven and available solution. I love the idea of BD, but it will require patience, so all depends on if you're in a hurry or not...
