"Sangaku" New York Times
Discussion in 'Project Logs' started by greensabbath, 7 May 2005.
  1. zackbass
    zackbass What's a Dremel?
    8 Aug 2002
    If the whole thing turns out as completely *expletive* awesome as the work you've done so far, this will be one of the most beautiful cases I've ever seen. I really love your details like the fan grilles and the ebony wedges.
  2. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    finally an update, sorry, the shop wasn't open on sunday, anywho, i've been doing some painting of the fan blades and the cover of my dvd burner:
    a bunch of coats of primer first:
    then some nice gloss black paint:
    alright, i also got my heatsink....
    [​IMG] so pretty, anyways
    i figured it was finally time to start attaching things to the front acrylic, and the fan came first. this wasn't too hard, just 4 holes and 4 brass bolts (that will be painted black) that go from the front plate, through the fan, and connect to the back fan grill. what's not pictured in any of the pics here are the panty hose that will act as my fan filter, and will clean up the look of the fan from the back.
    more finished pics of that later, the fan casing will be anadized black, so it will be quite pretty with all the other blackness, especially contrasting against the wood.
    the next step was cutting the hole in the front plate for the dvd drive to come out. there were a few ways i could have done this, ie. router, scroll saw, by hand, but i decided in the end to use the metal mill that my school has.
    i did a couple of test cuts on the test piece to find the correct speed:
    after that seemed fairly successful, i went on to cutting the real peice:
    and it turned out pretty nicely:
    and here are the rest of the pics of what is done on the actual case so far, i can't wait to take the paper off of the front, it should make things look a lot better:
    sorry for the blurryness of some of these
    oh, and a sneak peak of whats hopefully to come unless i screw up or i think its ugly, the texture for the soon to be anadize front doors (with a hole in them of course for the fan)
    this is a nice 3/16 inch slab of aluminum that i'll be banging on for a few days, definately fun, anyways that's it for now.
  3. kaltag
    kaltag What's a Dremel?
    11 Apr 2005
    You are doing an absolutely beautiful job! Please keep up the great work and craftsmanship.
  4. ctrl_alt_del
    ctrl_alt_del What's a Dremel?
    25 Feb 2005
    wow! this is incredible, great detail! keep this thing going!
  5. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    this IS going to be sick
  6. IYIENACE
    IYIENACE What's a Dremel?
    30 May 2004
    Ah, that's a great idea. Simple too. :thumb:
    (I'm not crazy about coming out of a store with just pair of panty hose though lol)
  7. f0r.0h.4
    f0r.0h.4 What's a Dremel?
    10 Mar 2005
    Take off the paper! Take it off now! Please......................pretty please.
    This is going to be amazing.
  8. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Can't wait to see how the textured metal comes out. Those fans are gonna look great when you get em anodized black.
  9. Freaky_Tweak
    Freaky_Tweak What's a Dremel?
    11 Oct 2003
    This is a beautiful case mod, and only keeps getting better. I am looking forward to seeing more progress on this case. Keep up the good work :D :thumb:
  10. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    greensabbath,
    this is beautiful! One of the best full cases I've seen come around for a while. Keep up the great work!
  11. dex2407
    dex2407 What's a Dremel?
    9 May 2005
    AMAZING your work is second to none
    (you wanna come panel my bathroom) :)
  12. Alwayz Dead
    Alwayz Dead What's a Dremel?
    5 Mar 2002
    Superb work. :thumb:
    You are a credit to your proffesion.
  13. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Sweet. Finish this with pride and you might eventually have a cooler case than Zap is doing now.
  14. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    This case is going to be amazing. By far the best wood-using case in existance, unless there's a sliver caught somewhere in ORAC^3.
    Personally, I wouldn't put a door on the system. However, it's your case, and your choice. Either way, it's going to look really good in the end.
  15. greensabbath
    19 Apr 2005
    i've been having some second thoughts on the front doors too, one reason is they're gonna take forever, so i might just save those for later, since i can do them after everything else is done. oh, the shoji doors are probably the next thing to be done.
  16. steff79
    steff79 What's a Dremel?
    10 Dec 2003
    Mhhh... I love wood. Looks so nice...
  17. -Erik-
    -Erik- Guest
    We'll see, Zaps' qwheel is gonna be the bomb .. but this is surely interesting. :hip:
  18. Leinie
    Leinie What's a Dremel?
    4 May 2005
    I think we have meet the Norm Abram of Modding! Way to go. That case is lookin' Sweet!!!!! :clap:
  19. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    go on dude wanna see more update like youre idea`s
  20. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Without a doubt! Much classier, I really like what you are doing with this case.
    Excellent craftsmanship, nice Mill too, btw! :D
