Hardware Sapphire Pure Platinum A75 Review
Discussion in 'Article Discussion' started by arcticstoat, 7 Nov 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Or use a mini-PCI SSD that won't cause your installation to drag along at a snails pace, and less likely to suddenly die due to NAND failure (an SSD controller is built to hand that kind of workload, an SD card controller is not). After buying an adapter and a SD card from a reputable brand, the price difference won't be too great either.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    a sapphire pure motherboard that isn't white? come on :(
  4. randis1981
    randis1981 What's a Dremel?
    4 Nov 2010
    please revision MSI Z68A-GD65 (G3)
  5. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I wouldn't even use a sapphire motherboard in you P.C.
    Bios updates are non existant and they are impossible to communicate with as they all speak Engrish.
    They should leave motherboards to the professionals.
Tags: Add Tags
