Hardware Sapphire Radeon HD 5970 4GB Toxic Review
Discussion in 'Article Discussion' started by CardJoe, 11 May 2010.
  1. Jediron
    Jediron What's a Dremel?
    22 Jul 2008
    I hope not, as if that would be "the preferred" standard; monstrous powerconsuming hardware. Where does it end ? 2000watts? 3000watts? 4000watts? Isn't there a moment you think; wow; this is going way out of hand ?
    Yeah, maybe when your electric bills start to show enormous figures....that will help.
  2. karx11erx
    karx11erx What's a Dremel?
    17 Dec 2004
    The big con of this cooler setup is that it doesn't blow the hot air out of the case. Having a fan in the case's side wall is mandatory here. I know what I am talking about: I had once been cooling a HD4870 with a similar AC cooler, and had to add a fan to my case's side wall to keep it from overheating (and since the case didn't have a fan grill in the side, I even had to drill holes in it myself).
  3. sharpethunder
    sharpethunder Minimodder
    25 Mar 2010
    SLI GTX480s cost around this much, could we get benches vs that aswell?[/QUOTE]
    pointless they would use alot more power and the temp would be alot higher as well prob cook them selves
  4. rollo
    rollo Modder
    16 May 2008
    lol sharpe
    this isnt about heat or power this is pure performance
    i want sli 480s benched agaist this.
    If you can pay £1k on graphics cards your power bill isnt the most relivent part of your month lol
  5. Jediron
    22 Jul 2008
    It will do, if your bill equals the price you've paid for them ...lol
  6. harryy
    harryy What's a Dremel?
    13 May 2010
    re:Hardware Sapphire Radeon HD 5970 4GB Toxic Review
    Hello,
    You gave very good information i visit this website.my name is harry i am new here .
    thanks
  7. Mraedis
    Mraedis What's a Dremel?
    5 Sep 2009
    Other reviews have SLI GTX470's/480's against this, and they score about the same, mostly won by the 470's/480's. Overall, the power draw is lower on the 5970, temps are lower but, it is louder (subjective analysis). It costs less than than the 480's, but more than the 470's. (Taken from hexus, not my material.)
  8. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    pointless they would use alot more power and the temp would be alot higher as well prob cook them selves[/QUOTE]
    They won't. The temps of a GTX480 in Tri SLI was only 3 deg more than a lone card.
  9. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    So that's 103 as opposed to the ice cold 100 degrees they normally run at?
  10. AshT
    AshT Custom User Title
    9 Jul 2009
    +1
    There are people on these boards who are fine with high bills and extreme performance.
    [shout]... KEEP PEDDLING WOMAN, POWER FADING AND I HAVEN'T PRESSED 'Submit Reply' YET!!![/shout]
  11. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Finally something worthy to replace my 4870x2!
    If I can get my hands on two, ill post the benchmarks.
    Also to the BT reviewers, what is with testing gpus at ultra-low resolutions like 1,680 x 1,050. Your time would have been better spent hooking up 3 27" and 3 30" monitors in an Eyefinity setup, THAT is the exact reason this wonderful Beast has 4Gb of ram. So do a follow up review with eyefinity.
    1100$ is a reasonable price point for gear of this level, I do hope the run is more than 1000 units though.
  12. sharpethunder
    25 Mar 2010
    i have put an order in with my local shop for one of these beast anyway
    and may order a second 0ne have not made my mind up though
  13. Picarro
    9 Jun 2009
    I - for one - use 1680 x 1050, but I follow you. I probably won't be gaming with a card like this at such a low resolution.
  14. rickysio
    6 Jun 2009
    They're designed to run at those temps?
  15. bangbe2009
    bangbe2009 What's a Dremel?
    15 May 2010
    Where can i buy this graphic card..?
    Is it really already sell on market...?
    Or just sample from sapphire for review only..?
  16. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Designed?
    I'm sure if Nvidia could've made them run cooler, they'd be running cooler. The high power consumption (and thus high heat output) are the main cons of the Fermi series.
  17. Jediron
    22 Jul 2008
    No kidding ? People who don't care much what's happening with our envirement, you know, that silly planet we live on. What do you care, you will be long dead, right ?
    Me, me, me, more, more, more... does that sound familiar ?
  18. AshT
    9 Jul 2009
    Oh thats great. I recycle like a *******. Compost everything I can. And you come here wasting my precious carbon savings with worthless BS. Cheers.
    Oh and while you are on your 'save the cheerleader world' crusade can you have a word with China?
  19. Shayper09
    Shayper09 Swimming in Deionized.
    14 Jun 2010
    Mmmm. This in CF with a 980x, 24gb of 2200 Mhz ram, OCZ vertex 2 solid state drives in raid 0. Excuse me while i go rob a bank =]
    (FIRST POST Cheesecake)
Tags: Add Tags
