Storage SAS or SATA for my storage array?
Discussion in 'Hardware' started by KayinBlack, 9 Mar 2010.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I just picked up an AWESOME SAS/SATA controller card http://www.6thstreetshops.com/int-srcsas18e.html for cheap on Ebay, but in the interest of space/speed, should I short-stroke SATA drives or should I be looking at SAS for RAID and then some SATA for storage? The goal is 5+TB, however I get there, and to keep up with the rest of the system (2x8347HE Opterons, 8GB ECC DDR2, currently 4870x2) if I'm outputting from something like CATIA.
  2. Mister_Tad
    27 Dec 2002
    All depends on your i/o requirements, how will you be using the array?
  3. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    What are you going to be using the 5TB for? If its just storing media, SATA drives will be fine and you'll have enough cash left over to buy a SSD or two for your system drive.
  4. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    He says it's Dassault Systemes's CATIA (very heavy CAD program, used to design whole planes...) so I gess his i/o may be a bit high, but as I don't know the exact requirements for Catia maybe SATA is still enough ?
    Also, budget ?
  5. KayinBlack
    2 Jul 2004
    I was originally considering using 8x36.4 SAS drives in RAID 10 as a boot/main partition, and then performing dumps to a set of SATA in RAID5 on the motherboard controller.
    However, should I simply run a large RAID partition and go that way?
  6. saspro
    saspro IT monkey
    23 Apr 2009
    What's the budget for the drives?
  7. Mister_Tad
    27 Dec 2002
    Again - all depends on your I/O and sequential throughput requirements - any ballparks?
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    catia isn't that much more intensive than Solidworks, there actually virtually the same, except catia has more advanced tools for dealing with mechanical performance of the design.
    So storage isn't the bottleneck for such applications, just raw processing power. Sure a pair of back to back drives in RAID 0 would help a little in loading the design into the memory, but hardly affect actually working speed of the application.
    SATA should be fine
  9. KayinBlack
    2 Jul 2004
    Basically anything will be fine, so long as it is redundant. I think my question is answered.
