Small Form Factor Sata Cables
Discussion in 'Hardware' started by jaffamunsta, 10 Sep 2004.
  1. jaffamunsta
    jaffamunsta What's a Dremel?
    26 Aug 2004
    When you buy a shuttle do you normally get sata power cable adapters or is the psu already fitted with them???? My SB83G5 is comin on monday and ive only just thought about it :duh:
  2. jaffamunsta
    26 Aug 2004
    Sorted
    No probs managed to get two from a local pc shop, what luck :D Roll on monday :thumb:
  3. AndyT_uk
    AndyT_uk What's a Dremel?
    13 Sep 2004
    do you know if the shuttles usually come with the sata cables?
    i'm ordering a sn95g5 soon so i need to know whether to add them or not?
    Cheers
