SATA II Backwards compatibility...
Discussion in 'Hardware' started by Brooxy, 4 Sep 2007.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    OK time for a stupid question...
    Can a SATA II device work in a SATA I port? Albeit with a lower transfer rate?
    Thanks
  2. Mister_Tad
    27 Dec 2002
  3. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    They can, a lot of SATA-II drives actually have a jumper pin to change the mode.
    Some even come with SATA-I mode set and to use SATA-II you need to remove the jumper, or at least was the case with my Seagate drives.
  4. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    my seagates are identical apart froim the fact that one is a SATAII drive.. What jumper are you referring to delphium?? i have found none..
  5. capnPedro
    11 Apr 2007
    My Barracudas have a TINY little gray jumper next to the SATA connector. Just pull it off to increase the theoretical transfer rates. In actuality, nothing changed, but the drives seemed to play nicer with my RAID ocntroller. ???
  6. mk-donald
    mk-donald bits and bobs
    2 Aug 2007
    Best to check your specific planned Sata II drive's website for details of how - eg I think my Hitachi drive ships as Sata1 and you have to run their proprietary software tool to 'upgrade' to Sata II.
  7. Firehed
    15 Feb 2004
    I'm pretty sure that the SATA spec as a whole requires compatibility between drives and controllers of different revisions, much like PATA drives at different speeds do. If both the drive and controller have a SATA plug, it should work, at the slower of the two if they're not the same speed.
  8. Delphium
    18 Mar 2007
    There was a little jumper next to the SATA and power connectors on my 500gb barracudas.
    pic source from hothardware.com
  9. 3dHeli
    3dHeli What's a Dremel?
    25 Jul 2007
    I'm using SATA II 3gb drives, on a 4 year old Dell with SATA I and all I do is set drives to 1.5gb via little jumper . . . very easy, no problems.
