Build Advice SATA III/USB 3.0 PCI Card
Discussion in 'Hardware' started by CoffeeTwoSugars, 11 Jan 2012.
  1. CoffeeTwoSugars
    CoffeeTwoSugars What's a Dremel?
    9 Jan 2012
    Hi guys,
    I'm looking to buy a SATA II/USB 3.0 pci card for my build, i'm a little confused as where I can put it. My motherboard is an H55 model and I have one PCI slot in use already for my sound card and the PCI express is covered up by my graphics card so I cant use that.
    So all I have left is the second slot for the graphics card and by the looks of it, the cards I have seen won't fit in this. Any ideas or solution? Am I overlooking something completly simple and being a complete noob? :worried:
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Any 1x, 4x, 8x, 16x card will work in a 16x slot. Just use the 2nd 16x slot for the controller card.
  3. CoffeeTwoSugars
    9 Jan 2012
    Does this mean that a PCIe card won't work in the X16 slot? I have had a look on scan and ccl etc... and can't find any cards which are standard PCI.
  4. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    What he said. Just go with the lowest priced one that has the features you need.
