Modding Sata power cable problem
Discussion in 'Modding' started by jaywebster, 28 Jul 2010.
  1. jaywebster
    jaywebster What's a Dremel?
    28 Jul 2010
    Hi guys,
    I wonder if anyone can help me.
    I have some sata power cables that I want to make shorter between each connection.
    I have removed one the the connections, they are the self crimping kind. I am trying to replace the connection now but I cant seem to get the wires into the connections again. Is there a tool I need to do this or do I just need to apply more pressure?
    Can someone give me some advice?
    Thanks
  2. capnPedro
    11 Apr 2007
    IDC punch down tool is the proper tool for the job, but just use a flat screw driver. Put some electrical tape or something over the wires to prevent messing up the insulation.
  3. jaywebster
    28 Jul 2010
    worked, thanks for tip :)
