News SATA SDHC RAID spotted
Discussion in 'Article Discussion' started by CardJoe, 12 Aug 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    ;) I think the "6" is missing...
  3. WildThing
    WildThing Minimodder
    26 Jul 2007
    Cool nifty little gagdet, but nothing more I think. Like you say, RAID 0 with 6 SDHC cards, sounds dangerous! :eeek:
  4. cjoyce1980
    cjoyce1980 What's a Dremel?
    17 Jul 2007
    hopefully you should be able to recover the data on the other cards if one does die on you.
    nice concept though
  5. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    6 SDHC Cards?
    So, we're talking a maximum of 48GB using 8GB cards.. It's roughly £15 per card, that makes it £90... Then £48 for the unit..
    We're talking £138 for 48GB of SSD storage, here.
    Is that really worth it? I can see pretty much no point to this.
  6. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    No option for anything else like RAID 5 then? That would certainly make it more tempting...
  7. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    It is a RAID 0. The data is broken up and striped across the drives. If you save a file, no matter what the size, pieces of that file will be on all the drives. That is how you get the increased read/write speeds. Trust me, if one drive goes, that is it for everything. Even using heavy recovery tools you would only be able to recover small system files that were smaller than the stripe size.
  8. naokaji
    naokaji whatever
    8 Dec 2006
    simply too slow to be worth it (ssd is faster, like for example ocz core) , besides, how reliable are SDHC cards? I doubt they have a very high mtbf if used 24/7.
  9. SixthEnigma
    SixthEnigma What's a Dremel?
    12 Aug 2008
    Raid Data Integrity -- If it weren't for the limitations of laptops, you could always fit two of these drives and set up raid mirroring between them :)
  10. p3n
    p3n What's a Dremel?
    31 Jan 2002
    go lookup RAID 0 :)
  11. identikit
    identikit Minimodder
    5 Jun 2004
    Yep, people commonly refer to RAID 0 as "RAID 0; the number stands for how many files you'll get back if it fails"
  12. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    I'm not sure it should even be allowed to bear the "RAID" moniker. The R does stand for redundant y'know.
  13. Anakha
    Anakha Minimodder
    6 Sep 2002
    And yes, you lose one "Disk", you lose everything. Just like a non-RAID1 or RAID5 system. Though if you can identify the bad "Disk", you only need replace that one "disk" to get back the capacity you had. Unlike an SSD, where if the SSD goes down, you have to replace the whole SSD. No data recovery option there, either.
    Personally, I think this is a great idea, it's just a shame the cost for the SDHC cards isn't lower. Still, get some 133x (Or higher) cards in there and you'll have a "Drive" that has 0ms random-access time AND massive bandwidth, the holy grail of storage. Stick your Windows partition on that, and store all your media on a 1TB 5400 RPM drive, and your storage won't be the bottleneck anymore.
  14. Scottyman
    Scottyman What's a Dremel?
    12 Aug 2008
    I'd be interested if it was in P2 presentation, as this isn't quite flexible enough yet... looks like it's taking steps toward it - ideal for broadcast media
  15. Xir
    Xir Modder
    26 Apr 2006
    "I'm afraid that you'll have to find another use for those hundreds of 512MB and 1GB cards that seem to accumulate every time you buy a new gadget."
    Uhhh my Gadgets are officially limited to 1 GB ;-)
    The three devices that do use SD cards (camera, car stereo and navigator) all state that they don't support more than one GB...never tested this though.
  16. Xir
    Xir Modder
    26 Apr 2006
    ...so if you have hundreds of spare 512 and 1GB cards... I'd take them for the car stereo :-D
Tags: Add Tags
