SATA to PATA converter
Discussion in 'Hardware' started by Darkedge, 23 May 2005.
  1. Darkedge
    Darkedge Member
    26 Nov 2004
    Having problems with my sata interface and booting in windowsxp 64 - so I'd like to try and use a SATA drive through my perfectly working PATA interface.
    Does anyone know where in the UK i can buy a SATA drive to PATA cable converter?
    ta
  2. Highland3r
    Highland3r New Member
    25 Jul 2003
    Have you set sata as boot, and does the boot drive have sata drivers on it?
  3. ben_jt
    ben_jt New Member
    6 Oct 2004
    Found an identical query from a few days back...
    Is this thread the same as what you're asking? If so, see my reply in there.
    :idea: :search:
  4. Darkedge
    Darkedge Member
    26 Nov 2004
    it's what i want and yeah i'd like it to be sold in the UK please :(
  5. ben_jt
    ben_jt New Member
    6 Oct 2004
    Read it again - the product I linked to is on a UK online shop!!
    www.megadataonline.co.uk, specifically... (No idea where the other guy found it cheaper though)
  6. Darkedge
    Darkedge Member
    26 Nov 2004
    aha! thats the one.
  7. Darkedge
    Darkedge Member
    26 Nov 2004
    actually no it isn't thats ide to sata not the other way round. I need to plug a SATA drive into a PATA IDE interface.
  8. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    Not possible afaik, sorry.
    [EDIT]Nevermind, i didn't think you could do it that way but by the looks of it you can, expensive peice of kit tho :( [/EDIT]
    Death
  9. riluve
    riluve New Member
    29 Jun 2004
  10. ben_jt
    ben_jt New Member
    6 Oct 2004
    THis is the second time this has been misunderstood... the device works as you want it to, like so:
    [MOTHERBOARD PATA CONNECTOR] -> [MAGICAL CONVERTOR BOARD] -> [SATA CABLE] -> [SATA DRIVE].
    You plug this into the IDE controller on the motherboard, and get two serial ATA connectors to connect your serial ATA devices to.
    That's what you said? Plug your SATA drive into a PATA interface? Here's your piece of kit.
    :wallbash:
  11. Darkedge
    Darkedge Member
    26 Nov 2004
    right - I checked even with the makers site and that isn't clear at all.. shame that site doesn't have any in stock :(
  12. riluve
    riluve New Member
    29 Jun 2004
  13. Darkedge
    Darkedge Member
    26 Nov 2004
    riluve they are US and don't ship to UK.
    The others still out of stock
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    Buying a cheap HDD is gonna be easier than sourcing such a non-standard convertor.
  15. riluve
    riluve New Member
    29 Jun 2004
    Oh
  16. wharrad
    wharrad New Member
    26 Jul 2003
    Could try a SATA PCI card... They're getting pretty cheap these days. Allow you to add another drive or two in future aswell.
    Yep, I know that'll put the drive through the PCI Bus, but just one drive won't be hurt much.
