Windows Saving Steam updates?
Discussion in 'Gaming' started by Guest-16, 9 Jun 2005.
  1. Guest-16
    Guest-16 Guest
    Since i have to install HL2 several times between each system and updating takes FOREVER, i was told that i could save steam updates for HL2 and CS:S onto disk, then apply them on reinstall? If so - can someone tell me HOW?
    Thanks.
  2. sheardjr
    sheardjr Minimodder
    7 May 2003
  3. mushky
    mushky gimme snails
    24 Mar 2003
    Can't you right click the HL2 icon in steam and select "backup" and whap the whole lot onto a DVD? Something like that anyway.
  4. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    that's been a bit hit and miss for me, worked twice, not worked twice, and it takes forever and a day, easier to just dump the whole steam dir to another backup place and copy over once reinstalling a basic steam installer on new setup
  5. Firehed
    15 Feb 2004
    I've used the backup feature with good success. On the other hand, I've had much less success just copy/pasting everything. Of course, that's inevitably due to me installing to a wierd directory (ie, not the standard c:\program files\valve\etc) and I forget which level of folders it goes to lol.
  6. Guest-16
    Guest-16 Guest
    So easier to copy and paste the whole steam dir to DVDRW then :) Cool thanks.
