Sb Live 5.1
Discussion in 'Hardware' started by Visualaid, 12 Feb 2004.
  1. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    Hi guys.
    I am having serious problems with my SB Live 5.1 It wont play any sound and it says there is a bad driver. However i try and update and it says that it wont update because of bad previous driver. How can i fix this tried un installing all sound things and re installing but nothing. Btw. i;m on XP.
  2. Krikkit
    21 Jan 2003
    Remove all traces of the card from XP (including the game port controller etc etc), then remove it, reboot, replace it into the machine, reinstall it into XP - always worked for me :)
  3. Visualaid
    15 Apr 2003
    i try in a minute.
