Modding SBLive Platinum Cable Mod
Discussion in 'Modding' started by :: kna ::, 16 Mar 2001.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Ok, well after successfully rounding my SBLive Platinum 5.1 interconnect cable, I thought I'd give Biz-Tech the scoop on how to do it.
    1. If you look at the original cable which comes with the 5.1, some holes are plugged up and they've labelled where you're supposed to to connect the cable with a black dot. It's important to take stock of where everything is supposed to go so you can tie this up to the new cable you're going to use.
    Make sure this cable is long enough! A lot of IDE cables are around 450-500mm in length, the SBLive cable is roughly 600mm, so don't be misled.
    A normal IDE cable has the connector clamped in the opposite direction to the SBLive cable, so I'm going to remember where everything goes by following the red wire. I'm unsure if (unlike IDE) you connect this cable the wrong way round whether you're going to get 12v somewhere you don't want it, so pay attention to orientation.
    Finally, make sure you do not use an IDE cable with a 'hole' cut somewhere along the 12th (or so) lead in. This is for HDD 'cable select' and may cause problems with the SBLive.
    2. Here you can see a normal IDE cable on the two SBLive parts, the first picture is on the 5 1/2 bay section, notice the red cable on the right. The second is on the PCI card and here the red cable is on the left (as we look at it upside down). It's not well shown here, but it'll look odd as the cable is looped back on itself to achieve this.
    [​IMG][​IMG]
    3. Time for food.
    4. Ok, with it wired up, the next thing is to test operation of the SBLive, obviously there's no way to hear it however the next two pictures show the IR Remote working and the headphones. I've not tried any of the digital out or line 2 in, however I am confident they will work. (If not, you'll know all about it soon enough).
    [​IMG][​IMG]
    5. Now time to round the cables. I'm not going to do a piece on how to round 40 pin IDE cables as there's a million sites which tell you how to do that already, the concept is exactly the same.
    6. And here, they're in! The colour correction on my crapcam makes it look like I live in some psuedo red and blue 3d world, however hopefully you can see them. It looks a lot cooler than the picture gives it credit for.
    [​IMG][​IMG]
    And there you have it, a simple mod that possibly many people might not have considered. The best part is, if it all goes wrong, you still have your original cable!
    YEHBABY likes this.
  2. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    sweet, keep it up Kna!
