Whats wrong with aluminum? My dual coolmatics are aluminum with a copper core, still keep the cards nice and cool and they can be removed seperatly
PLUS... the advantage of 2x waterblocks is that you can sell/upgrade them seperatly.... so if SLi isnt as good as it looks you can sell one block and one card instead of both cards cooling hmm... just realised on dangerdens site they have an A8N chipset block... designed specifically for the A8N... im definatly considering one now, although id want to get pushfit connectors on the block im sure i can get them and fit them.... your mod is just getting better and better... keep up the good work
Not much of a update but its somthing lol, I was changing my ram over today when, i went to put the sidepanel back on and i was turning the screw and it wasnt going in, then i looked and realise the one on the left had threaded , so i came up with a solution that matched the rest of my case and also gave me better peace of mind at a lan, since nobody normal carrys allen keys, (should be safer ) Well here we go, both sides are the same. The bolts are the same ones iv used through out my case, i think they match pretty well I removed te spring ones, and retaped the hole to 5mm to match the bolts, they fit in nicly and blend quite well. On the subject of updates um still waiting on the logo to me made, im hopefully getting 2 made, one out of aluminum and one of out blue plexi All comments Welcome Sc4mpi Out...
Hello again... well it has come to that time of year to mod again , and well im looking to implement a second watercooling loop take the cpu and the old loop to power the gfx's and chipset Has a go yesterday mounting the second res. ^^^ This is my crude plan for were ot put a second pump and how to tube it up lol was done at 3 in the morning before i went to bed so excuse the crappyness Only snag im having is were to put a second pump whist retaining neatness The second loop will use the front 120.1 and a black ice pro im going to mount on the back 120mm fan. Need all recomdations on were to shove a pump and what pump to get. cause im stumped lol ta... sc4mpi out.
Pumbed it into my existing loop this morning Untill i decide what pump to get.... Needs to be smallish and very quite. im thinking maby another hpps but dont no were to put it
Since im waiting for the parts for the second loop to arrive ill deal you with some eye candy. (p.s my photography skills are crap lol ) but at least u get the picture Sc4mpi out.
Hey Sc4mpi, looking very nice, great work. How are your temps now i.e. cpu, graphic cards... I know that case is giving you great ventilation.
if the fans are set at 12v gfx 34. cpu 26 5v gfx 44 cpu 33 passive cpu 40 gfx 54 i wana see what its like with the dual loops
I see your 6800's have that little green light too.... I guess it'll screw with both of our color schemes Still, looks nice.
you could jsut put a bit of blue tack over them, iwas going to but then it kinda matches the psu colour lol
That looks lovely man.... im loving the way that dual 5" res looks in the front of the case! i need to make my own res at some stage... as this asetek one is too damn small!
At 2.30 in the morning i jsut fitted the second loop - minus the black ice pro Was only able to take one crap pic before cam ran out of batts anyways im off to bed.. All comments welcome , better pics in the morning.
