Sc4mpi's V1000SLi - Stage 1 done.
Discussion in 'Project Logs' started by sc4mpi, 17 Jan 2005.
  1. [ShoNuff]
    [ShoNuff] New Member
    10 Sep 2004
    As a fellow A8N-SLI owner...Me too!!!
    Curious to see how the GPU blocks fit on the PCI-E cards.
    EDIT: When are you going to get your video cards?
  2. XTS Gun
    XTS Gun Member
    1 Dec 2003
    Man thats some awsome power your puting in there :thumb: Keep up the good work.
  3. Firehed
    15 Feb 2004
    Same, although mine's in transit to newegg after (what I think is) a fried chipset :duh: :waah: :worried:
    Looks very promising - my system will likely be very similar but in a v2000.
    And ACK stop saying PCIX, those are PCIE connectors!!!! Two different things!!
    [/pet peeve]
  4. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? New Member
    13 Jun 2004
    mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm i like the looks of those video card Blocks............qeustion, what kind of CPU chip you got going? i believe you are getting a stocket 939 if i remember correctly, and i just want to say i see alot of potential for this project, so don't let Bit-Tech down!!
  5. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    They have been ordered But airnt in stock for at least another 2 weeks which is kinda ok cause the rest of the water parts arint going to be here before then :)
    At the moment just a 3500+ 90nm most probily.
    As of yet im not 100% sure it might probily go somthing like this
    HPPS>Innovatek XX-flow>120.1>Nv-40>Nv-40>120.3>Graph-o-matic>bayres
    Hopefully that will work , right going to fit top rad todays :)
  6. 3t3rn@l
    3t3rn@l New Member
    29 Nov 2003
    nice setup wish i had that kinda hardware going into my puder :wallbash: :D goodluck with the project looks like its going to be interesting, cant wait to see how it performs :D
  7. sc4mpi
    16 Jan 2005
    Been messing about with the top radiator and it fits very snug now
    Top 120.3
    Still need to put grills and clean up the edges
    Place im going to mount the pump... :)
    What ya Think so far ? :D
    Brading kit should be coming somewhen (im not looking foward to brading all these cables lol :eeek:
  8. Leeum
    Leeum New Member
    16 Feb 2004
    Nice and clean, lovin it :D Any plans on adding some 120MM grills to the top?
  9. sc4mpi
    16 Jan 2005
    Lol give me time :D
    There you go :naughty:
  10. Crazy_Seb
    Crazy_Seb New Member
    15 Jun 2003
    NIGHT PICS!!!! lol. I love blue 120mm fans, and here's 3 in a row :eeek: Show me pleaaaaaaase. :clap:
  11. XTS Gun
    XTS Gun Member
    1 Dec 2003
    Let me know how that thing cools :D
  12. sc4mpi
    16 Jan 2005
    iv just merged the two holes in the bulkhead into one and played the little clips were i think they should go to hold the tubing nicly. Will get some pics in a mo.. :)
  13. Xarig
    Xarig New Member
    26 Feb 2003
    Looking forward to see how the water cooled SLI cards work out. I've got the same motherboard and intend to build a similar rig :naughty: It'll be interesting to see if there's enough room to avoid 90 degree turns in the tubing.
    I'm subscribed :clap:
  14. [ShoNuff]
    10 Sep 2004
    Do you have enough room to add a soundcard? This thing is going to be "Schweeeet" when you finish.
    Looks good. :dremel:
  15. ModKid
    ModKid New Member
    5 Jul 2002
    those " muffled " cables as you call them are to remove any noise that the harddrive or videocard might generate. It also provides a more stable power connection to the videocard and the harddrives.
    OCZ Sells these kind of cables as well, i have a review on it on my website.
  16. sc4mpi
    16 Jan 2005
    I know lol, there Shielded cables just on all the reviews of the 520watt powerstream none of them have 3 or them leads they all had 2 were as this one has 3, must have been a new version :)
    p.s There is one pci slot free if i wanted a sound card but tbh i want to see what the onboard sounds like first. :D
  17. Raymus
    Raymus New Member
    29 Jun 2004
    When I first read you were cutting 3 120mm blowholes in a brand new Lian Li case. I thought you were crazy. But after seing the results the cuts are perfect. What did you use to make those cuts so nice? BTW rig is looking killer. Also i noticed in your sig you had a watercooled Shuttle. Any chance you could post a few pictures of it? :rock:
  18. sc4mpi
    16 Jan 2005
    i just mounted the pump and the pipe holders to hold the tubing nice and neat :D
    over all pic (you can now see the merged bulkhead hole :)
    Pump mounted on the anti vibration bolts
    Pump holders Blue tacked in place to get ruff idea
    Cuts were made with a 120mm Holesaw :)
    And shuttle pics well here u go.. (p.s they aint been resized)
    [Removed]
    Side
    [Removed]
    Front
    [Removed]
    top side
    [Removed]
    Night shot :naughty:
    Thats it for tonight
    Sc4mpi out...
  19. KAMIKAZE-FREAK
    KAMIKAZE-FREAK New Member
    30 May 2004
    Gots some pictures of the interieur of that shuttle?
  20. Bboy_Jon
    Bboy_Jon New Member
    28 May 2004
    sweet mod, is that mobo like a micro atx or something? looks really tiny
