the A8N SLI is a full atx motherboard, i presume it looks small cause it only has 3 pci slots and the radiator was covering them so it made the motherboard look small
This is lovely n all scampi, but do you mind cutting your sig down to 4/5 lines-ish? Or make it go across?
It's not a micro atx, they don't make SLi micro atx (yet). The rest of the mobo is simply hid behind the radiator.
cpu has now been ordered (3500+ winchester 90nm) and gfx cards they hopefully will be here next week somewhen Cpu and chipset waterblock should ahve been here by now (emailed the shop they said they were dispatched 3 days ago )might haft to see whats happend to them
Look what just turned up... Innovatek xx-flow Rev 2.0 (has solid silver base if im not mistaken) this thing weights more than my danger den blocks its actuly very nice Graph-0-matic for chipset .. Nice and blue And A64 Clampdown. http://www.members.aol.com/progamer99/holddown.jpg Will fit them in a bit just for show.
Cpu and Chipset block mounted Out side view close up of chipset block Close up of cpu block and pipe holddown. (theres no cpu under the block btw) Looks quite swanky i think
cool WB's for cpu and chip Lian-Li is lookin real good too. One of my favourite cases of all and good to see people doing nice things to it.
cant you reroute your power wire's who are on the right side? my opinion is that they are to much in sight
Yeah i agree, it wouldn't be as bad if the wires were sleeved a nice dark blue to blend in with the tubing. Loving your work so far, the black PCB and blue blocks look so nice together
hum haft to give that some thought, so what your saying put a hole under the socket on the mobo and feed it up from the bottem?
You would benefit from better cooling (water temp and air flow inclusively) and lower noise if you have your fan suck air out of the case, not blowing in
The at the rear of the case, the cables would trace easily up to the sockets from there keeping everything clean
My bad But I mentioned "water temp", so its implicitly the ones on top of the Rad. Nice work anyway, keep it up.
