Sc4mpi's V1000SLi - Stage 1 done.
Discussion in 'Project Logs' started by sc4mpi, 17 Jan 2005.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    the cats taken joppo sorry :D
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Looking GOOD. Keep it up!!
  3. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Ahh my confusion is cleared, thanks bud
    looking awesome, man.... keep up the amazing work :dremel:
  4. [ShoNuff]
    [ShoNuff] Minimodder
    10 Sep 2004
    sc4mpi, did you modify the chipset bracket in order to make it fit. I have the same block and I noticed the bracket come very, very close to the resistor that sits next to the green cap?
    It looks like I may have to cut that piece off of the bracket. :confused:
  5. frodo
    1 Nov 2003
    hmm... i might have read this and forgot
    what size tubing does the graph-o-matic take? as i really need a low profile chipset cooler for an SLi rig ive got planned.. if its 10mm OD ill be overjoyous ;)
    take care
    btw... your mods still looking schweet
  6. stu_69
    stu_69 What's a Dremel?
    11 Mar 2004
    Look good mate. Keep up the good work. I wish I wasn't so poor so I could afford to mod my pc (infact I want to completely change everything)
  7. sc4mpi
    16 Jan 2005
    Yes i bent the bit of the clip up that ,that came near the resistor (could have cut it off, but then it ruins the clip)
    Yep its 10mm OD 8mm ID :D
  8. frodo
    1 Nov 2003
    thanks mate... thats really good.. hopefully it will work on a DFI SLi-DR... any chance of a picture of the space between the graphics cards and the chipset block, or would that be basically impossible due to the fact that the pc is now in the case
  9. RetroPimp
    RetroPimp What's a Dremel?
    23 Feb 2005
    Wow man you have an awsome setup there. I have the same case and want to water cool it. I've basicly had the same idea as you. Putting a 120.3 rad in the top however when putting the rad in I noticed that if the fans were mounted inside the case it would cover up my PCI slots, rendering my Audigy zs usless. So i've been thinking about mounting them on the top of the case. But i'm thinking it might ruin the overall look of the case. So i'm stuck in a dilema. :confused:
  10. sc4mpi
    16 Jan 2005
    i doubt the chipset block will work with the dfi as the second card will be sitting right on top if it.
    I recon you can still fit a 120.3 there depending on what mother board you want.
    If it wasnt a sli setup then you would have 2 pci slots free your could use.
  11. [ShoNuff]
    10 Sep 2004
    Welcome to the club. I am in the same boat. Like sc4mpi I installed a Evo 360 inside of my V1000 using my Abit IC7-Max 3. I have a OpAmp modded Audigy ZS and can not do with out it. I just bought this rad and the outside has a brushed aluminum finish that matches the V1000 pretty well.
  12. ebola_one
    ebola_one What's a Dremel?
    22 Sep 2004
    I'm not sure if you're still pursuing the logo idea, but what if you come up with your design (text/picture/whatever) and laser cut that into a plexi/perspex cover.
    Attach some shiney metal (stainless Steel, Aluminium, whatever) over the top of the drive cage (where you have indicated), and "hover" the plexi over the top using some mother board stand offs or something.
    You could even add some kind of light to the edge of the plexi to highlight the edges of the laser cuts. Or, have some soft glow projected over the metal.
    Does my ramble make sense? :)
    Nice work anyway!
  13. sc4mpi
    16 Jan 2005
    yep i am still persuing the idea, but im jsut waiting for a replie for the guy with the lazer cutter :)
  14. ColJack
    ColJack What's a Dremel?
    23 Feb 2005
    what is the distance between the drive cages and the side of the case?
    could you fit a custom made thin acrylic reservoir in there?? with your logo stenciled on the side?? just a thought....
    also, i don't know if you know about this, but gainward have a SLI set up for that motherboard with a special SLI waterblock...
    they are also making a 512MB PCI-E 6800 Ultra now... ( 1Gb in SLI mode..... )
    links and pics follow...
    Linky to the news page...
    C.J.
  15. sc4mpi
    16 Jan 2005
    Yer iv seen that gainward sli block before, its nice and all but:
    1. it Wount fit under my top rad.
    2. i wanted the abilty to remove the cards seperatly
    3. it costs WAY to much for what it is.
    4. only works for the asus a8n sli board (poor dfi owners :hehe:)
    Res idea - never though of that before but would be a bit anoying if i had to get to the drives. might think about it though
    512, 6800ultras - gainward is still developing them and 2x of them cost the same as my whole system put together... :eyebrow: , But i woulnt say no if they offered them for free :hehe:
  16. Firehed
    15 Feb 2004
    5. it's a bit on the fugly side
    and about the 512mb cards, it's still only 512mb effective in SLI mode since both sets of ram need to hold the sama data. Part of the reason 6600GTs don't offer even more performance improvements than they do in SLI mode, it's still only 128mb effective.
  17. NicePants42
    NicePants42 What's a Dremel?
    16 Jan 2004
    6. It's aluminum.
  18. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    DD has a new waterblock connector. I know you cant use it but heres a linky.
    http://www.dangerden.com/ bahh front page new news
  19. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    aluminum isnt really any worse then copper you guys...
    The difference is not very noticeable.
  20. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    I like the Gainward one, although I would have thought they would incorporate red in there somehow, seeing how everything they make is red. But I understand it is innovatek's hardware.
    I think the DD one is hideos actually. Maybe it looks better in person but man is that thing fugly in those pictures.
