Modding Scalpel...Check, Swab...Check, Dremel....ooer!
Discussion in 'Modding' started by Marzupial, 21 Apr 2002.
  1. Marzupial
    Marzupial What's a Dremel?
    29 Oct 2001
    Just thought u guys would like to know about this list of cool "Techno Tools" from Dans Data.
    Tooooooools
    Oh and before u ask, i own a Blowtorch. :D
  2. therider
    therider What's a Dremel?
    11 Mar 2002
    Tapered reamer:
    looks nasty!
    ride
  3. Vectrex
    Vectrex What's a Dremel?
    21 Apr 2002
    He's got some pretty good suggestions. Those would all be great to have, if only you had the money. Has anyone here used one of those nibblers? I've heard they work pretty well for windows, but I wanna know what other people think.
  4. Grump
    Grump The Mad Modder
    30 Mar 2002
    Did someone say nibbler? Howsabout this'un:
    I used it to cut part of a window opening today and it's pretty sweet. I still like my jigsaw better though.
    And my Dremel replacement is this hum-dinger:
    I talk about both of these here.
    Grump
  5. mashie
    mashie The one and only
    15 Mar 2002
    I used a similar hand powered nibbler for most of the cutting on Syrinix (everything except the window since I didn't have the nibbler by then). It worked fine to cut 1mm copper, just remember to use a glove or you will get blisters from it...
    I was looking at a electric nibbler but the £300 pricetag was far too much for my taste, might get one in the future though since I like the way they work.
