Hardware Scan 3XS Scorpion-X PC Review
Discussion in 'Article Discussion' started by arcticstoat, 24 Mar 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
    Oh I so want one of these :)
  3. knuck
    knuck Hate your face
    25 Jan 2002
    The inside looks very nice but the outside....... OH GAWD ! QUICK , SOMEBODY STAB ME IN THE EYES !
  4. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    The only part about this pc I like is the case, but the rest of it seem's very low spec for the price and would prefer 2 or 3 GTX 580's in it instead of the GTX 590 given the new review.
  5. NuTech
    NuTech Minimodder
    18 Mar 2002
    Doesn't Bit-tech have (or had?) a business relationship with Scan? If so, doesn't reviewing one of their products pose a slight conflict?
    Wouldn't bring it up usually, but I cannot remember the last time I saw a pre-built PC reviewed by Bit...
  6. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    It only has a relationship in the same way that Crysis 2 and other games are advertised on the site, as are lots of hardware manufacturers do too, like OCZ, Gigabyte, G.Skill, etc etc.
  7. phuzz
    phuzz This is a title
    28 May 2004
    "we saw the CPU temperature reach 95°C"
    Watercooling - You're doing it wrong.
    I'm not sure what they're doing wrong, but the CPU temp really shouldn't be that high, especially as the GPU is at a lower temperature. Did you check the waterblock was properly fitted?
  8. NuTech
    NuTech Minimodder
    18 Mar 2002
    The partnership could be over, but this was posted only last year:
    Link.
    I think the relationship is slightly deeper than the simple advertising campaigns you listed above.
    I don't think there is anything inherently wrong with it (I've been reading Bit for more years than I care to count and value their extensive reviews), I just think maybe a disclaimer or two wouldn't hurt. Even low-quality blogs like Kotaku mention at the end of their reviews how they obtained the software/hardware and if any business relationships exist.
  9. rollo
    rollo Modder
    16 May 2008
    £3700 The words must be joking ring a bell
    And 95c CPU temp on water wow my x58 980x on water at 5ghz with 1.45 vcore doesn't reach that insane temp, something is wrong with the water cooling I think.
    Nice looking pc though
  10. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    look - I'm old and silly - how does cool air get into the case is all the fans are exhaust?
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    Through the meshed side panel cut-outs.
  12. Tech NoOb
    Tech NoOb What's a Dremel?
    12 Feb 2011
    From the top, see third picture. The top fan (formerly the rear fan as components have been rotated 90 degrees) sucks air in and you also have gaps in the top of the case.
  13. soviet_
    soviet_ Bantros
    17 Dec 2008
    Why would anyone spend an obscene amount of money on a PC housed in a case with those horrific decals plastered on it? Money can't buy taste apparently
  14. Tech NoOb
    12 Feb 2011
    Actually the top fan maybe drawing air out. Weird fan logistics. Too pricey as well. You could probably build the system for half the price.
  15. knuck
    25 Jan 2002
    as much as I agree and hate the looks of it, I'll give it something; those aren't decals, the panels are laser cut (it's said in the article :D)
  16. soviet_
    soviet_ Bantros
    17 Dec 2008
    Whoops, I read that @knuck but I didn't think it meant the scorpion was laser cut, looking again I see the mesh underneath. Still, even more pointless! All that effort for that result :)
  17. Claave
    Claave You Rebel scum
    29 Nov 2008
    They're laser-cut holes, not stickers - please read our articles before posting.
  18. koaschten
    koaschten What's a Dremel?
    24 Mar 2011
    Well the obvious fail in this box is definitly trying to cool an overclocked i7-2600k and a GTX590 with a single radiator that is either 360 or a 420... nonetheless, too little surface area.
  19. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Yeah.. erm.. so who's to blame for this turd?
    F'ugly, expensive and hotter than hell. Do. Not. Want.
  20. soviet_
    soviet_ Bantros
    17 Dec 2008
    I was so disgusted by what I was seeing I must've misread. You should have a warning on that review, "stroke inducing content ahead" or a pop-up box asking your DOB and if you are over 15 you get kicked to the front page
Tags: Add Tags
