Modding School Project, Making a case
Discussion in 'Modding' started by Sedge, 2 Jan 2003.
  1. Sedge
    Sedge What's a Dremel?
    14 Jul 2002
    Right here i go...
    for my AS school project i am making a pc case.
    sounds simple...well it aint as you will probally know!
    just woundering if any had had any mods go really wrong, because i really dont want to make any mistakes.
    or if you have any ideas you want to give me.
    please relpy!!
    Sedge :D
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    PLAN PLAN PLAN Take it slow and PLAN PLAN PLAN
    ...oh and measure twice and cut once.
  3. loply
    loply What's a Dremel?
    26 Dec 2002
    Something Ive found PHENOMONALLY usefull in designing things like cases is to meticulously construct the entire thing in 3D Studio on the computer beforehand - Including every screw and washer.
    It will find all the engineering/architectural problems before you come to them and let you optimize the design hugely.
    If youre not familiar with a particular piece of 3D software though then it wont be much use to you. Guess youll just have to do it really carefully on paper.
  4. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    another good technique is to build your box using a full scale mock-up. make everything out of cardboard or something of the like. There's no substitute to seeing how/where the components are going to fit in your box.
    Also, consider your skill set and what tools you have available in your design. Keep it real so you will have successful execution. A perfect execution of a mediocre design is better than a crappy execution of a great design.
    Take pride in all the details... it pays.
    Oh, and welcome to the boards! :rock:
  5. tk421
    tk421 Idiot.
    15 Jan 2002
    and remember ... totally ghetto parts can make for a super sweeeet™ case ... like that guy that makes those copper cases out of plumbing supplies ...
  6. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    What materials are you working with? I'd look into finding out as much as possible about the material. How to cut, how to glue, physical characteristics can all be helpful.
    I dunno, I tried that. I cut the same board three times and it was still too short.
  7. m00min
    m00min What's a Dremel?
    6 Jul 2002
    i r build hdd cooler for AS project with 3 papst 40mm fans, anodized aluminium and a nice circuit that turned the fans off when the hdd reached room temp :D
    good luck
  8. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    I believe it is "measure thrice, cut once" :D .
    AstrumPreliator
    ":grr: "
  9. ?
    How can i get the form of a case?, which materials are used to get a case?, can anyone here explain me the steps to meke one case?
    JUST ASK!!!
  10. Astrum
    8 Mar 2002
    It's pretty simple Rebel. The form of a case is a box, 6 sides. The materials are whatever you want. Iron, Graphite, Aluminium, Plutonium, Acrylic, Glass, Phosphorus, Plastic, Poop. The possibilities are limitless. All you need to do is design what you want it to look like (a box with holes), get the materials (see list above), and start cutting and putting it together!
    AstrumPreliator
    ":grr: "
  11. Crim
    Crim What's a Dremel?
    1 Jan 2003
    psst. Make it out of polished aliminium, or chrome, it would look super cool. :rock:
  12. olv
    olv he's so bright
    23 Sep 2002
    Plutionium! Arf! Now that would rock :rock: :D
  13. Fronzel
    9 Mar 2002
    I was looking at getting a bending brake and making a box of my own. I've got a specialized application that they don't make a viable case option for.
    A non hydraulic brake good up to 16 gauge should be about 50$US.
    If you have access to a machine shop possibly even a welding shop, they may have one they would let you use.
  14. Astrum
    8 Mar 2002
    I was actually looking at those Fronzel. I found a couple for about $50 USD. And would actually work well for 1mm thick steal/aluminium/copper/ or the new popular choice, plutonium :D .
    I was also thinking about getting a powerder coating system. So I could put a clear coat on, bake it in, and then have a well protected case. I saw one for about $120 USD. I think when you add it all up, the supplies to make the case are less than the materials :p .
    AstrumPreliator
    ":grr: "
  15. Fronzel
    9 Mar 2002
    Ohhhh.... I forgot about those.
    I was looking at one of these. They don't make a bug screen for my truck in my favorite color, Chrome. They said I should be able to get it to hold up to road use.
  16. Astrum
    8 Mar 2002
    That was the exact one I was looking at! Hehe. It's so versitile. I just don't have a place to bake the paint on. I don't really want to use my cooking oven ya know...
    AstrumPreliator
    ":grr: "
