Case Mod - In Progress Schwarz Mirror V2.10
Discussion in 'Project Logs' started by WeisseS, 7 Jul 2010.
  1. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    no no no! Nothing against you at all, I just think it's pretty poor the job google is doing. Because I know it's got to be google right? If it's not google and it's you, then I apologize as I did not mean to insult you, only point out the poorness of google's translate feature.
    Please take no offense in what I said, you have a great beginning here and I in no way am trying to discourage you.
  2. WeisseS
    WeisseS Italian Modder
    24 Sep 2007
    No problem Logan, usually i use babel fish to translate from italian to english,
    I can speak English but use a translator but for convenience
    is not very precise.
    I do look more carefully in future ;).
  3. Dudey109
    Dudey109 Minimodder
    20 May 2010
    Love the mirror effect, cant wait to see the fans against it :)
  4. WeisseS
    24 Sep 2007
    Thank you Dudey, i' m waiting for other parts, maybe suterday i will post other photos ;)
  5. WeisseS
    24 Sep 2007
    Today's update is about mobo-backplate!!
    My friend Mino gave me a fantastic chromed backplate by Akasa
    I used some tape to cover the cutting site...
    ....and drew the guide line
    My dremel with diamond disc is ready! Go !!!!! ;-)
    Have a look at the "hole".
    Not bad.
    Fitting test....(FYI two slots have been removed because the backplate was too long for my purpose)
    It fit togheter perfectly.
    I refined the bottom side of the chassis to hold the Enermax revolution
  6. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Well done so far, even if the rivets' solutions dosen't make me crazy !!
    Keep on modding :dremel:
    Ciao
  7. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    Very cool. Looks like we'll be seeing a lot of you through this project log. :D
  8. WeisseS
    24 Sep 2007
    Thanks to all.
    Good news, my friend Dot_Kappa will help me to translate from italian to english :)
  9. logan'srun
    22 Apr 2008
    I like that idea of the 45° angle mobo tray, that'll look pretty cool!
  10. Attila
    Attila still thinking....
    22 Feb 2008
    Yes, and a great solution for cable management. :thumb:
  11. WeisseS
    24 Sep 2007
    Thank you guys,
    effectively it is an innovative solution.
  12. WeisseS
    24 Sep 2007
    Let's go ahead with the side panels.
    Onestly I think they are one of the most attractive pieces of the case.
    At the beginning I started cutting the side panel with my dremel but after
    a while I realized that wasn't enough for my needs...so I called my friend
    Mino asking for help and he gave me the contact of the tombstone maker :)
    Maybe it sounds a little strage but the side panels will be cutted with water-jet
    machines by a company that make gravestone!!
    Let me show you some pics
    The panel on the hardware side
    This is the turn of Plexishop, they engraved the logo on the plexi that will be
    placed under the panel I saw you before
    The logo "modded in italy" doesen't miss and It won't in all my future mods
    Side panel with plexi mounted. I like it !!
    Have a look at the panel in place.
    Side panel without plexi
    Take a look at the chromed profile at the top and bottom side of the panel
    Fixing plexi
    Both the logo and the line engraved Will be light up
    I can't wait to see the case finished!!
  13. WeisseS
    24 Sep 2007
    Go on...
    This is the other panel (on the psu side), made by the tombstone maker, with the new logo engraved!
    The side panel is 3cm longer so I decided to remove 1,5 cm from the top and
    bottom side.
    Some adhesive tape to set the cutting point
    The panel is fixed with some clamps
    An angular profile hlped me go straight with dremel (409 disc)
    Here it is...
    My favourites piece is the logo engraved on the mirrored plexy
    Once again some adeshive tape before cutting.
    Mirrored plexi in place under the alluminium panel
    Retro-lighting test
    It was just a test because the light will be white but I' am
    thinking of a bicolor system
    Panel in place
    ...without mirrored plexi
    Mirrored plexy installed
  14. Dudey109
    Dudey109 Minimodder
    20 May 2010
    Awesome update, really clean looking side panel, and the plexi fits nicely keep it up
  15. WeisseS
    24 Sep 2007
    Here I am guys!
    I assembled both side panels and for your interest there will be a gull-wing opening
    system like mercedes sls thanks two small gas pistons.
    Each panels is fixed a the top of the case with simple metallic clasp
    I removed a little piece of clasp both from the starting and ending point because was
    in touch with the chassis.
    I left the central bar in order to keep the general look
    Clasp fixed to the chassis...it looks nice!
    Strating from the panel on the psu side I marked the holes on the plexy
    The clasp is fixed with M3 bolts
    Even if I threaded the holes I put some nuts to strengthen the panel because of the movement
    This is how it looks like from the inside
    Obviously all the screw will be resized later.
    Now I can complete the side panel..
    I joined the plexy and the alluminium thanks to this bostik glue
    A little bit of glue
    Alluminium panel in place
    The glue is up to expectations, after 10 minutes was well fixed and 2 hours later everything
    was strongly fixed.
    This is the first panel assembled with clasp installed!
    Quick light test
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looks really sweet with the orange or red & then the blue light, looking great so far WeisseS & interested in seeing the finished piece with the different approach to mounting the motherboard :thumb:.
  17. WeisseS
    24 Sep 2007
    I've done the same work on the hw's panel.
    I applied some adhesive tape on the top of the plexy panel
    It's dril time
    I make the holes
    I fixed the clasp after removing the tape
    The plexy panel is ready so I laied upon the alluminium panel
    Whole panel fixed to the chassis
    Obviously the bulkheads are not yet anchored but simply positioned.
    Pay attention at the lower mirrored profile
  18. WeisseS
    24 Sep 2007
    Let's go on....I fixed the panel with the chassis.
    Starting from a plexy plate (1 cm thick and 8 cm wide 45 cm long) I made two little plates (2 cm wide 43,5 cm long)
    Here they are two plaxy plates,cutted with an electric jigsaw, ready to be placed both to the
    panel and to the top of the case
    Holes marked
    Bar drilled and holes threaded
    Hole in detail
    Thread
    Screwing the clasp to the bar
    ...from another point of view
    The clasp with all the screw in place
    Let's fix it to the top of the case
    The clasp fit perfectly!!
    The panel open
    The opening system is missing but the manual movement is ok.
  19. Benzaa
    Benzaa apologizes for his English!
    31 May 2010
    Nice work! I like the mirror effect and the gull-wing opening! :)
    Do you speak German or why have you chosen the name "Schwarz Mirror"? Your Username is WeisseS, also a German colour. :D
  20. WeisseS
    24 Sep 2007
    Thanks a lot, i will use a rgb controller to make the light effect.
    Stay tuned, today i will upload a lot of photos :rock:
