Scratch Build – In Progress Scorpio-completed
Discussion in 'Project Logs' started by Pranja, 15 Oct 2012.
  1. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Looking good so far, I like the fact that you are using older parts for the WC it shows your creativity, and it looks good! Is this case going to hold 1 or 2 computers it appears you have 2 front panels unless I'm mistaken.
  2. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thanks mate. :D
    No,this case is for only one computer. I used two front panels because front panel is chepar the just two front usb ports. So,I said-why not? You can choose between left or right side or even use both. My plan was to solder headphone jack from one to another so it can be used two hedphones at same time,but I decidet to leave as is-this with additional sound card could lead to interesting results. :D
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Here is the promised update. :D
    Today I have been testing the watercooling equipment and cleang radiators. I found out that my fittings on CPU block and reservoir are leaking like mad so I took reservoir from the loop and replaced fittings on CPu block with some barbs from old Thermlatake radiator. It worked,and radiator is now clean. I also ordered some fittings for reservoir from ebay.
    I also soldered cables to switches and placed front panel cables-cover from second microphone jack was removed.
    And one pic that I really like-sun made nice shadow on Scorpio next to Reaper.
    Final pics of today's update are here-they are the reason I waited with posting. I waited until was dark so I can take pics of LED's turned on. First one was in total dark,second one with light turned on and third was taken with flash on.
  4. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    LET THERE BE...... LIIIGHT:D
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Oh yeah. :thumb:
  6. Asouter
    Asouter --------
    18 Jan 2012
    Really Nice, but I am biased towards layered builds. Looking forward to seeing this one :)
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you. :thumb:
    Update will come next week with some good news.
  8. xSoMBrAx
    xSoMBrAx Member
    18 May 2011
    Excellent stuff Pranja!
    Keep it up :)
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you. I glad that you like this project. ;)
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Update time! :D
    First,I would like to thank In Win for providing their awesome Commander III 800W PSu for the project.
    It is really unique modular PSU with cool color scheme and 80 Plus GOLD certificate.:rock:
    And now-the case update. I finally received my new MBO tray thet will allow me to put ATX MBO inside of the case.
    Some comparison with the old one:
    This is how it will be fitted (of course,it will be straight):
    That's all for now folks-next update will bring completed prototype and then I will start with the real,plexi case.
    Merry X-mas. :clap:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Sounds good :rock: Merry Xmas mate. :)
  12. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you Waynio. Merry Xmas to you and your entire family.
  13. siliconfanatic
    10 Sep 2012
    Thats the present i was looking for! update on one of my fav current builds! looking good. makes me wish I could get sponsorship like that.
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Well I am not Santa Claus,so I can't give you present-but I can wish you Merry Xmas and fun-tastic holidays. :D
  15. k.3nny
    k.3nny Active Member
    27 Jan 2010
    I like where this is going man :D!
    Keep in mind that res is alu!
  16. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you an Merry Xmas.
    Don't worry,I have anty-corosion fluid. ;)
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
  18. dombak1608
    dombak1608 New Member
    3 Apr 2012
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    And I stilll hate FB. But that is not preventing me to sharing cooler giveaway that could be nice Xmas present for someone. ;)
    There will be more pics veeeery soon,just be patient.
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Today I fitted new MBO tray and improved a covers (added toothpicks as a spacers XD). Prototype is 95 % finished-I only need to fit holders for add-on cards. This will be done tomorrow when local hardware store opens. ;)
