Scratch Build – Complete ⭐ Scratch BL@ck: Only handmade crafted - 20 liters Slim ITX (10 cm Thickness) UPDATE 03.04.21
Discussion in 'Project Logs' started by Canardwc, 18 Apr 2020.
  1. Cheapskate
    13 May 2007
    You have gotten a LOT of use out of that HP side panel. :D
    @Jeff Hine -It's because I plan/design way beyond my abilities. This time the design only fits in a gantry cnc... from China.
    Canardwc likes this.
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Yes,
    this is why
    this is why
    this is why, I mod,
    mod cause you not,(@Jeff Hine ) ;)
    this why
    this is why I mod
    :D
  3. Canardwc
    22 Sep 2011
    Finised cuts and hemlines contour coore tray
    Lap sealant to cover holes:
    Dot_Kappa likes this.
  4. Canardwc
    22 Sep 2011
    It was a joke for cheapskate (in reference about your yesterday post; don't be offend) that he makes 5 years for mod because of his crashed CNC ;)
  5. Canardwc
    22 Sep 2011
    I've just sand the first mastic coat, and apply the second coat. AND, dry it faster in my oven :D
    :worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried::worried:
  6. Canardwc
    22 Sep 2011
    I didn't realise you wrote HP panel but in fact it's the left panel of a COOLER MASTER C960 II advance :naughty:. That make a BIG difference :lol:
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Great job with the tray.
    I hope you don't cook in that oven :worried:
    You should start...
    Materials and tools are such an investment for your second project.
    Because there will be a second one :grin:
  8. Canardwc
    22 Sep 2011
    Completly agree with you!
  9. Canardwc
    22 Sep 2011
    Sanding with water to prepare core tray to paint:
    Suspend it:
    Then paint it black!:
    All that work for that (my heart doesn't know if it was a worthwhile goal)
    Anyway, I've done the core tray recycling my Cm 690 II advance
  10. Canardwc
    22 Sep 2011
    Assembly core tray with hardware:
    DSC_0846.jpg DSC_0845.jpg DSC_0848.jpg DSC_0847.jpg DSC_0849.jpg DSC_0850.jpg DSC_0851.jpg DSC_0852.jpg
    censored_Prometheus_ likes this.
  11. Canardwc
    22 Sep 2011
  12. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Damn! Is not a Quasimodo! It... "I collected bones in the crypts; I used a blasphemous hand to invade the most precious corners of the human body. "
    Victor, it you? :jawdrop::eyebrow::lol::lol::lol:
  13. Canardwc
    22 Sep 2011
    Thks you very munnnnnchhhhhhhhh :jawdrop::jawdrop::jawdrop::jawdrop::jawdrop:
    Glad you like it, but I have to work a little bit more for "enclosure"
  14. Cheapskate
    13 May 2007
    Looking good. :D
    CM panel: Now that you mention it, It is kinda big. Your hand is tiny in comparison. :lol:
  15. Canardwc
    22 Sep 2011
    Thank you ;), from you I take it proudly :D
    Yes I know and a strange thing: since I began this new build, I feel younger each day too!!! :D
  16. Canardwc
    22 Sep 2011
    Sanding panel before applying hematite oxydizer:
    Crafting my power water sandig tool (piece of wood, paper sand, paper tape and a old white wine cubitenaire recycled in water fountain)
    Sanding with ater for hours and hours with different kernels of papers sand following steel vein (4 faces, almost 3 hours)
    Result of 3 hours of sanding: lot of steel dust with water looks like steel mud!
    But I appreciate the result:
    Then cleaning and preparing steel before its treatment:
  17. Canardwc
    22 Sep 2011
    Crafting a power switch and power (but still waiting the C14 connector) bracket supporting by the motherboard VGA and DVI:
    DSC_0868.jpg DSC_0869.jpg DSC_0870.jpg DSC_0871.jpg DSC_0872.jpg DSC_0873.jpg DSC_0873a.jpg
  18. Canardwc
    22 Sep 2011
    Little update today:
    Stick the foam band to isolate from vibrations between core tray/rear panel and also seperate/canalize differents airflows (GPU, CPU watercooling and PSU) to prevent mixed cold and warm airflow preserving hardware temperatures
    And that foam band will also hide screws between core tray and rear panel:
  19. Canardwc
    22 Sep 2011
    I've also done oxydation. It's a very quick reaction (oxydizing, washing with water, stopping rusting process with chemical neutralizer, wash with big water again, drying and waxing to stop as soon as possible corrosion chain...).
    All that should be done very quickly, otherwise... :duh::waah:
    So, I wasn't able to illustrate it with pictures... It was impossible to be in two places at the same time.
    But the render seems awesome to me!
    Now, I'm waiting C14 plug and i will put all together, shake them and then, i'll finish this scratch build. Hope people that follow will appreciate it.. Show the reslult in few days.
    Namasté
  20. Canardwc
    22 Sep 2011
    Just received and install C14 plug:
    DSC_0921.jpg DSC_0922.jpg DSC_0924.jpg DSC_0925.jpg DSC_0926.jpg DSC_0927.jpg DSC_0928.jpg DSC_0929.jpg
