Scratch Build – In Progress Scratch Build from 16 year old!
Discussion in 'Project Logs' started by Floris, 8 Jan 2020.
  1. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Love that you're getting into this at a young age.
    I would get some cheap Chinese single and 2-flute end mills, especially for plexiglass. Your cuts will improve drastically over using those burrs.
  2. Cheapskate
    13 May 2007
    Beware! A few years ago China flooded the market with super rough, non center-cutting bits. Generally, the better bits in 1/8" shank are the ones with the plastic collars on them. The collars are so you can change bits without resetting the Z axis. Get Japanese bits if you can.
  3. Nealieboyee
    14 Aug 2009
    Fair point thanks. I'm usually careful when I buy stuff online though. Avoid bad reviews and generally stick to Amazon if I can. Gotta love that next day prime delivery when you need them ASAP :grin:
  4. Floris
    Floris New Member
    12 Dec 2019
    Thanks! I have done a lot the last month, I got one 'almost perfect' distro, it's just a small one to ensure myself it was working and it did! I made more but they didn't come out that nice (chips were getting into the leadscrew and it was screwed) but now it won't happen any more hopefully.
  5. Floris
    Floris New Member
    12 Dec 2019
  6. Floris
    Floris New Member
    12 Dec 2019
    Thanks! I received almost all my bits and here are they Screenshot_20200214-090505.jpg Screenshot_20200214-090521.jpg
  7. Floris
    Floris New Member
    12 Dec 2019
    I bought 2 pairs of 5 pieces and on Amazon for 25€ and the day they were delivered I saw the exact same ones on AliExpress for 8€ together . Those ones are just rebranded and doubled in price on Amazon I think.
  8. Floris
    Floris New Member
    12 Dec 2019
    IMG_20200213_200853.jpg yesterday flushed the loop and dismantled it. IMG_20200213_200856.jpg
    Here you see the 'new' GPU terminal in place IMG_20200213_221707.jpg applied new thermal paste and screwed the block in place, test fitted the 24 pin extension and in the top left depinned the 8 pin extension and depinned it on the other side because I had +- 5 mm clearance to move the cables through this was the only option without tearing down the whole case.
  9. Floris
    Floris New Member
    12 Dec 2019
    Today I want to make the bends from the GPU terminal to the cpu and machine some cable combs for the 24 pin and make a small panel between the rad and the mobo
  10. Floris
    Floris New Member
    12 Dec 2019
    IMG_20200214_195935.jpg Did the 2 tubing runs this afternoon
