Scratch Build – In Progress [Scratch Build] Project BlackBird
Discussion in 'Project Logs' started by sagar, 22 Oct 2015.
  1. sagar
    sagar Member
    22 Jun 2015
    Hey guys,
    First of all, my name is Sagar and I am from India
    This is my very first mod.
    Project !dea,
    Basically I have been fascinated by the LOCKHEED SR-71 BLACKBIRD jet (holds the record for the fastest speed). That is where the name comes from as well as the color scheme.
    The parts that I will be using are:
    Intel i7 4770
    Gigabyte B85m D3H-A
    Kingston HyperX Fury 1866Mhz 8Gb(4*2) stick [4gb still to come]
    DeepCool DQ750 80+ Gold Semi-Modular power supply
    Gigabyte GTX970 G1 Gaming or Zotac GTX 970 AMP! Extreme Edition [Still to buy]
    Cryorig C1 or Raijintek Pallas [Still to buy]
    LED strips [Still to buy]
  2. sagar
    sagar Member
    22 Jun 2015
    Update 1
    The first renders, the final ones will be uploaded later
  3. sagar
    sagar Member
    22 Jun 2015
    Update 2
    Deconstruction of my old case for the motherboard tray
  4. sagar
    sagar Member
    22 Jun 2015
    Update 3
    The motherboard tray off, taking measurements off of the sketchup model and transferring them onto the tray
  5. sagar
    sagar Member
    22 Jun 2015
    Side quest 1
    Couldn't afford the Sabertooth mobo from Asus, so will try and build one if I get the right material to build it
    Right now am making a template out of paper
    A test fit on the motherboard, haven't cut the slots for the 24pin, 8pin, SATA, etc.
    It actually fits, just gotta get a few mm here and there and it's done
  6. sagar
    sagar Member
    22 Jun 2015
    More updates to come tomorrow.
    Got the final 3D model ready :thumb::thumb:
  7. sagar
    sagar Member
    22 Jun 2015
    Update 4
    Got the final renderings ready,
    All the rendering work is complete
  8. sagar
    sagar Member
    22 Jun 2015
    The materials that i would be using are:
    Wood
    Aluminum/Steel
    Acrylic
    and tempered glass for the front
    These are the measurements for the wood that is to be cut
    OFF I GO IN SEARCH OF TOOLS AND MATERIAL :lol::lol:
  9. sagar
    sagar Member
    22 Jun 2015
    Forgot to upload the diagram of the angles that would be connecting everything together
    Also wanted to clarify that all the parts that I am going to be building would be handmade.
    None of them machined just the cuts would be made using power tools, none automated
  10. sagar
    sagar Member
    22 Jun 2015
    Update 5
    New update.
    Had to go to anther city for the aluminum support angles
    Here they are cut
    They are not same in length due to the 45 degree angles that i cut.
    Removing the excess metal using pliers
    Removed as much as i could
    A sample of the base
    Filing and getting them to equal lengths is a work for tomorrow.
  11. sagar
    sagar Member
    22 Jun 2015
    Update 6
    Finally after 2.5hours of cutting and sanding got all the lengths equal as well as the edges smooth
    This is what the system will look like when assembled
    The mobo and PSU that i will be using are a bit longer on breadth as these are the spare and broken PSU and mobo respectively :cooldude:
  12. sagar
    sagar Member
    22 Jun 2015
    A tough decision to make
    3D carbon fiber vinyl or paint
  13. sagar
    sagar Member
    22 Jun 2015
    After all the cutting and sanding the final dimensions of the aluminum angles are
    Length = 488mm
    Depth = 166mm
    Height = 514mm
  14. sagar
    sagar Member
    22 Jun 2015
    Sorry the same post got posted twice and i dont know how to delete one :duh:
    Length = 488mm
    Depth = 166mm
    Height = 514mm
  15. sagar
    sagar Member
    22 Jun 2015
    I tried a coat of black paint on an extra aluminum
    angle and the finish with the paint is very satisfying
    So I'm going to go with paint
    Officially scrapping the carbon fiber idea
  16. Cheapskate
    13 May 2007
    Looks promising.:D
    Don't forget to leave room for your HDMI.DVI cable.
  17. sagar
    sagar Member
    22 Jun 2015
    Thank you sir.
    I already have enough space for the HDMI and dvi cables to fit properly without getting in the way of the fans on the top.
    It is just now visible in the 3d renders:thumb:
  18. sagar
    sagar Member
    22 Jun 2015
    Update 7
    Got the holes drilled and the only things left on aluminum are counter punching the holes, sanding and painting
  19. sagar
    sagar Member
    22 Jun 2015
    Update 8
    So finally found a drill to counter-sink the drilled holes
    This is how the angles look like after drilling
    After about 30mins of sanding and a broken nail the hands look like this
    But the final result was well worth the pain
    Now the only thing left is painting these angles orange
  20. sagar
    sagar Member
    22 Jun 2015
    Update 9
    Got the mobo plate cut off from the old case
    The wood would be here tomorrow.
    The pics would be up tomorrow
