Scratch Build – Complete ⭐ Scratch build project
Discussion in 'Project Logs' started by kpmodding_, 5 Nov 2019.
  1. kpmodding_
    kpmodding_ What's a Dremel?
    31 Aug 2018
    Hi this my scratch build project hope you guys like a made the frame from 22mm copper pipe then painted it black then a use copper pipe for loop which a polished up the copper wanted to try something different for the loop rather than ur normal straight runs so a went for the creative look think it turn out well in the end
    IMG_20190506_140942_074.jpg IMG_20190510_193542_008.jpg IMG_20190522_181656_416.jpg IMG_20190609_102312_538.jpg IMG_20190607_095117_888.jpg IMG_20190610_185823_877.jpg IMG_20190618_181241_820.jpg IMG_20190829_110417_601.jpg IMG_20190905_102629_139.jpg IMG_20190711_142207_171.jpg
  2. Cheapskate
    13 May 2007
    Oh, man! I know that wasn't easy. :clap: It turned out pretty cool, too.
  3. Hardbox
    Hardbox What's a Dremel?
    14 Sep 2017
    very good design in tube
    kpmodding_ likes this.
  4. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    VERY cool, and looks like it must have been a royal pain in the backside to pull off!
  5. PGTDESIGNS
    PGTDESIGNS What's a Dremel?
    13 Nov 2019
    Also like the copper and at least you don't have to worry about looking at discolored pipes in a years time :naughty::naughty:... Bending all that stuff and making it work not an easy task :)
  6. pcroombrasil
    pcroombrasil Minimodder
    27 Nov 2017
    nice job
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    I saw your mod on pinterest or instagram and I was looking for a work-log....:grin:
    The loop is hypnotic :lol: !
    Very cool result :clap:
  8. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    interesting loop desing, out of schemes for sure!
  9. RedWolfwere
    RedWolfwere What's a Dremel?
    1 May 2011
    i Love copper! Nice job! :D
