Modding scratch in plexi
Discussion in 'Modding' started by evil_t, 30 Sep 2003.
  1. evil_t
    evil_t What's a Dremel?
    30 Sep 2003
    I have scratched my plexi. Is there any way to remove the scratch?
  2. RancidFlannel
    RancidFlannel What's a Dremel?
    25 Aug 2003
    novus
    novus 1-2-3 polish works wonders--get it and some lint free cloth
    the dangerous way is to melt it smooth.....DONT DO THIS!!!!!
  3. djrusty
    djrusty What's a Dremel?
    20 Aug 2003
    I had a tiny scratch in the acrylic door on my case - I managed to successfully polish it out use T-Cut colour restorer for car paintwork. Just be gentle and only use a tiny amount.
  4. evil_t
    30 Sep 2003
    Can I use toothpaste? I have heard about someone who did that
  5. djrusty
    20 Aug 2003
    That 'whitening' stuff might work, dunno if I'd wanna try it though - could be a bit rough.
    :confused:
  6. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Don't quote me on this, but I think that the toothpaste trick only works on really small/light scrathes. And it actually just more fills in the scratches so they aren't as noticeable. I don't think it actually removes or polishes out the scratch. Novus is definitely the way to go.
  7. evil_t
    30 Sep 2003
    Ok. Then I will try that. Thanks
  8. KrazyIvan
    KrazyIvan What's a Dremel?
    18 Oct 2002
    Chrome polish works good too. Specifically Blue Magic chrome polish.
