Modding Scratchbuilt PC: cooling system and water-cooling feature
Discussion in 'Article Discussion' started by brumgrunt, 8 Jun 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. phuzz
    phuzz This is a title
    28 May 2004
    Nice work!
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    I like what you are doing with this Antony, :) your first scratch build done with normal tools showing to anyone who might doubt themselves that modding & scratch building is average Joe compatible without spending copious amounts of money & this what you are doing is far better than my first effort like most if not all first time scratch builders these days. :D:clap:
    When I say this I am definitely not joking. :D
    This was my feature piece, the great snake pit of awesomeness. :D
    :eeek: See, & if someone said it was ugly I'd totally agree with them... Now... :hehe: But back then I was pretty pleased with it indeed with it being my first, I just figured I could do better so persisted spending a little longer on each one but without that first one I simply wouldn't be doing what I do now & same or similar can be said for anyone who does this. :dremel:
    And yes that includes pro's of any level :D once upon a time they had to build skills doing something, just so happens it plays awesome to modding also. :):dremel:
    Think it took me an astonishingly long week to do this first scratch build, I had no patience back then. :lol:
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Makes me wanna do a scratch too again :p
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    You know you want to. :D:dremel:
  6. Combatus
    16 Feb 2009
    Thanks Waynio! TBH, you had the harder project by far for your first scratchbuild - acrylic is so much easier to work with. I think I'd probably have cried by now if I'd used any more metal than I have already and considering you mainly use hand tools and scroll saws for your works of art - that's just amazing!
    But yeah, I wanted to make this project using little more than a Dremel and a heat gun to make sure the whole project costs as little as possible and needs just basic tools to make. I guess I've spent around £40 on materials so far and the rest has been scavenged. Not including the cooling gear of course - you'd have to buy that with any new PC. I've been impressed with how much you can achieve for relatively little cash (compared to a high end case for example). Looking forward to finishing it though!
Tags: Add Tags
