Modding Scratchbuilt PC - Materials, Donor Cases and Ports
Discussion in 'Article Discussion' started by brumgrunt, 19 Apr 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    First to comment? WOW!
    Nice mixture of techniques.
  3. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Excellent series so far, and good to see that you've opted for tools that are within everyone's reach. Not everyone can get access to CNCs, laser cutters, 3D printers, etc.
    Although I didn't realise that a Dremel's routing bit would be that handy; now that I think about it, it makes perfect sense... I really will have to check which bits by dremel-clone came with (and whether it's the attachments I was using or the collets that are wonky...)
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    I never tried routing with a rotool before, looks effective. :)
    Great series. :clap:
  5. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I wouldn't have thought using a glue gun on acrylic would stick very well, especially around the USB ports. Anyway it was a nice little read, thanks BT.
  6. Parge
    16 Jul 2010
    Ah! This is so good! I'm going to be referring back to this for years to come!
  7. Combatus
    16 Feb 2009
    The glue gun seems to have worked very well - we'll be keeping an eye on it, though. Thanks to everyone who's enjoying it so far!
  8. Parge
    16 Jul 2010
    Combatus, on a mostly unrelated subject, do you have any recommendations for cheap and cheerful cases for a WCing setup? Probably need at least a 360 or equivalent as the GPUs are SLI 480's.
  9. Parge
    16 Jul 2010
  10. Combatus
    16 Feb 2009
    Several spring to mind although a triple 120mm and budget don't usually go hand in hand! Also take a look at the case mod index - plenty of water-cooled cases in there such as this NZXT Phantom with a triple in the roof.
    Cooler Master ATCS 840
    Cooler Master Cosmos S
    Many of the larger Corsair cases
    Also this one by BitFenix looks like it might well fit a triple 120mm rad in the roof, if you're up for some modding and it only costs £37!
  11. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Adding this for future reference!
  12. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Antec 900 V3 or 902 fit a tripple in the front extended HDD bays.
  13. mi1ez
    mi1ez Modder
    11 Jun 2009
    This is going to be useful - hoping to do my first scratchbuild in the summer!
  14. richms
    richms What's a Dremel?
    24 Mar 2003
    Looking good. The new ITX boards are rekindling my interest in making a small custom case since it will be useful.
Tags: Add Tags
