Modding Scratchbuilt PC: More water-cooling and the roof section
Discussion in 'Article Discussion' started by brumgrunt, 2 Nov 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. guvnar
    guvnar What's a Dremel?
    19 Aug 2010
    "End result?" Hardly, there's black tape holding it together...
    Please finish it then post pictures so we can see the real "end result"!
  3. Combatus
    16 Feb 2009
    We can't show what doesn't exist ;) This is part seven of a diary of guides and lots more to come where we finish the roof section. At the moment this is all there is to see before we've cut it to shape and ironed out the bumps. We'll be showing more progress in the next instalment ;)
  4. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I thought you guys had given up on this, nice to see some more progress it's looking good.
  5. mclean007
    mclean007 Officious Bystander
    22 May 2003
    To get a nice smooth curve in the acrylic, lay it out over a pipe of the appropriate diameter, which then supports it along the entire length of the bend, rather than trying to bend it into place on the case, which only supports it at 2 edges. That should let you get a beautiful even curve.
Tags: Add Tags
