Scratched CD
Discussion in 'Tech Support' started by Spacecowboy92, 13 Sep 2007.
  1. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    I have a CD that's slightly scratched. It can play with very minimal performance implication but do you any tips on copying it to my harddrive at the best quality possible. Best programs and what settings ect. Thanks.:thumb:
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    ExactAudio Copy?
  3. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
  4. Spacecowboy92
    10 Apr 2006
    I use EAC usualy but it comes back with read errors and stops with this CD. It may have something to do with the settings I'm using.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    EAC has a "skip track on read or sync errors" checkbox, make sure it's clear. You could also set error recovery to medium, see if that gives a playable result.
    Other way is to clean and fill the scratches with something like Scratch Wizard
    Also check software recommendations here.
  6. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    Get yourself some like Disk Docter to try and minimise the scratch, then copy it.
