Anyone know of any software the i can use to capture video from games and save as an avi. games i'm looking to record are direct x thanks
A lot of games have a Screenshot button, otherwise, you can probably just use the "Print Screen" button, then paste it into something even as simple as paint...
Sorry, misunderstood - there's a shedload of different terms for still images taken from a screen. Good luck.
try fraps. i use it to get fps info, but it also supports screen & video capture for both d3d and ogl games.
straight from fraps' help file: Code: When I view the AVI movie I only see a quarter of the screen. How can I capture the entire screen area? Fraps can only currently capture at a maximum resolution of 640x480. Make sure that you configure the game to use this resolution before recording a movie. Also disable anti-aliasing if it is currently enabled. and as far as i know, fraps is freeware, i.e. no full versoin to speak of ...
