Windows screen control prog
Discussion in 'Software' started by total zombie, 24 Dec 2014.
  1. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    hi, im looking for a good prog that can allow me to tell program windows and screens what to do, eg telling a prog to open in a particular screen, when launching a prog do not disable another screen etc...
    any ideas would be great thanks!
  2. creative
    creative 500rwhp
    23 May 2014
    are you using multiple screens?
    If so, I use DisplayFusion Pro. It allows setting of different wallpapers or screensavers etc etc but also allows snapping of programs when they open.
    For example, at work I have outlook open on the left screen, main office program opens on the center screen and my web browser to open on the right screen.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Along with creative's suggestion of DisplayFusion, you may also want to look at UltraMon if you wanted a free, probably less feature rich program. If you don't mind forking out £16 there is also Actual Multiple Monitors that comes with plenty of features.
