Cooling Screw size for mounting fans to BIX???
Discussion in 'Hardware' started by Rai_Polo, 20 Jun 2007.
  1. Rai_Polo
    Rai_Polo What's a Dremel?
    20 Apr 2006
    Does anyone know the screw size needed to mount a fan to the Black Ice rads? I spent an hour in home depot this weekend and bout several kinds and still couldn't find it?
    Lemme kno.. or if you know where I can get them in Toronto that's even better..
    Thanks.
  2. Guest-23315
    Guest-23315 Guest
  3. Nexxo
    23 Oct 2001
    3mm (M3) "self-tapping" for the old model, 4mm (M4) normal threaded for the new GT series.
  4. Guest-23315
    Guest-23315 Guest
    M3 threads on the older BIX's aswell AFAIK
  5. Rai_Polo
    20 Apr 2006
    Cool.. thanks alot guys!!!
  6. Rai_Polo
    20 Apr 2006
    DAMN!!! I called Home Depot/Cdn tire and RONA and none of them carry these screw? WTH?
    Someone in toronto please tell me where you got your screws? please
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    http://www.dangerden.com/store/product.php?productid=221&cat=86&page=1 product info page for Black Ice GT Stealth. I'm sure that the same goes for the other radiators in their current generation.
    So if you cannot find the metric screws, try looking for the 6-32 SAE size.
    What length do you need?
  8. Rai_Polo
    20 Apr 2006
    I wish I had a newer gen, this would be alot easier. I have an older gen BIX and the holes are smaller.
  9. Stuey
    20 Jan 2005
    Oh. Yea, that's a different case entirely.
    I had to use sheet metal type screws to hold mine in place, and they were only secured by one or two threads.
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Dude, go to canadian tire or some other ****, and pick out the bolts by hand. They should have M3 x 40mm, if not, get M3 x 1.5", or tap them yourself to 6-32.
  11. Krikkit
    21 Jan 2003
    I just used through-bolts for my BIX G1, the fins bend quite nicely out of the way (if you're careful) and there aren't any veins in the way.
  12. Nexxo
    23 Oct 2001
    That is correct. In fact I (carefully) drilled out the holes of my BIX to M4 diameter with a drill press. Of course you don't try to drill through the radiator to do the holes on the other side!
    I then put M4 threaded rods all the way through. Only a few fins were bent; the channels remained untouched. The BIX is about 45mm deep; if you make the rods an inch longer, you can stand the fan off the radiator and wrap around a shroud (made from an aluminium strip) like I did in my case.
  13. Rai_Polo
    20 Apr 2006
    Wow.. that's some awsome advise.. I have a drill press, so I'll try retapping them to 6-32 since I have alot of those screws..
    Hope I don't screw this up.. lol..
    Thanks guys.
  14. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    BE very careful and run your press on the lowest speed it states for thin brass. that way you have more control. being hasty will just leave you with a leaky radiator. I put a piece of balsa under mounting hole when i drilled mine as extra protection for the channels.
    Another option is to use small zip ties. they worked very well on my BIX2 in one of my cases.
