Other Screwdriver magnetiser
Discussion in 'Hardware' started by wyx087, 27 Sep 2020.
  1. wyx087
    15 Aug 2007
    I’m finally fed up with dropping screws with my non-magnetic driver. It works well, but really difficult to work on those hard to reach places due to inability to reach in.
    Any recommendation on a good magnetic screwdriver?
    What about those magnetiser? Are they worth getting instead?
    I see LTT uses some sort of ratchet screwdriver, it can still hold screw on its tip. Worth getting? Which one would you recommend?
  2. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    Get a set of long slim screwdrivers with magnetised tips and a few short ones.
    wyx087 likes this.
  3. ElThomsono
    ElThomsono Well-Known Member
    18 Mar 2005
    I have the Wera star demagnetiser, it works like magic. One swipe and you have a strongly magnetic tip, another and it's flat dead like it's not even made of metal. Less than a fiver.
    MLyons, The_Crapman and wyx087 like this.
  4. wyx087
    15 Aug 2007
    So those magnetiser works. Do you need to swipe every time you start to do a build? Or do they keep the magnetism for a few weeks?
    I have a single one that works well. I’m thinking those magnetiser are the easiest for me.
  5. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    I just stripped the actuator magnets from an old HDD. A couple of swipes with that and I'm good.
    wyx087 likes this.
  6. ElThomsono
    18 Mar 2005
    I was amazed at how well it works. They'll stay magnetic permanently, then swipe and it's gone again. I should have got one years ago.
    wyx087 likes this.
  7. wyx087
    15 Aug 2007
    My Dad has one many years ago. It’s really strong and I can imagine it doing the job. Unfortunately he can no longer find it.
    Thanks all. I’ll just buy a magnetiser, simplest and cheapest solution.
    Fiver, perfect.
    https://smile.amazon.co.uk/Wera-050...etiser&qid=1601197642&sr=8-1-fkmr0&th=1&psc=1
    ElThomsono likes this.
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  9. David
    7 Apr 2009
    This is my super fancy pants mag:
    Dragging the screwdriver along that groove between the two mags will demagnetise it really quickly - literally a few wipes. Dragging across the pads magnetises just as fast.
    Osgeld, adidan and wyx087 like this.
  10. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    I've got the wera one and it does work really well.
  11. wyx087
    15 Aug 2007
    It arrived late yesterday and I moved the NVMe drive with heatsink under the graphics card to see whether the cheapo heatsink is any improvement over mobo heatspreader. It wasn't. So I moved it back.
    Magnetism is strongest imminently after swipes, unsurprisingly. Could pick up 2 screws sometimes. An hour later, it's not as strong but still does the job holding 1 screw to easily screw in. Repeated de-magnetise and re-magetise feels like magic.
    The screwdriver need to be good quality. The crappy tiny one came with M2 heatsink works somewhat, only just manages to hold one tiny M2 screw.
    Bloody_Pete and ElThomsono like this.
  12. Osgeld
    Osgeld Active Member
    9 Jul 2019
    Ya I have done that forever works a treat
  13. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Also have the wera one and it's worked perfectly
